problem with my abs
Old Dec 8, 2002 | 12:35 PM
Disco Monkey's Avatar
Default problem with my abs
my abs activates whenever i am at low speeds trying to stop.
i am not pressing the brake very hard and it keeps doing it everytime i am coming to a stop.
the brake only pulsates like twice and then stops.
it happens when there is no reason for it to be coming on
my abs light is not on either and i tried to get a code from it by way of the little connector under the dash on the passenger side. but nothing
any help?
Old Dec 8, 2002 | 02:01 PM
b19coupe's Avatar
Default Re: problem with my abs (Disco Monkey)
Have you had any brake/axle/wheel bearing work done recently? Hit any rocks or other foreign objects? If one of the teeth on the little ring gear on your outer c.v. joint becomes damaged, the abs will activate every time you step on the brake. It will not throw a code, because as far as the abs unit knows, everything is normal. It sees the broken tooth as a slipping wheel.
Old Dec 8, 2002 | 02:03 PM
Default Re: problem with my abs (b19coupe)
yeah i have had axle and wheel bearing work done but its been about a month and its just started now.
but ill look into that though
thanks
Old Dec 8, 2002 | 02:13 PM
Honda Hick's Avatar
you gotta do more sit ups and crunches. That should tone your abs but get on a diet if you have alot of fat between the skin and the muscle.
Old Dec 9, 2002 | 01:15 AM
IntEGNYC's Avatar
Default Re: problem with my abs (Honda Hick)
lol
Old Dec 9, 2002 | 01:43 AM
epy's Avatar
epy
I hope that wasn't 4 real
This made me laugh also: "My posts per day on average is weak as hell. Hey, I choose my posting wisely "
[Modified by ^colyer, 2:43 AM 12/9/2002]
Old Dec 9, 2002 | 04:23 AM
Red!ine's Avatar
Default Re: problem with my abs (^colyer)
Old Dec 10, 2002 | 07:48 PM
Snail Tuning's Avatar
My peddle hops under 10mpr when im beaking. hops 2wice then its done. or if im at a sertan speed it keeps hoping. someone told me i have air in my break lines. i haven;t gotten around to bleeding them yet. but id try that. let me know if u fix it.
Old Dec 10, 2002 | 08:06 PM
Default Re: problem with my abs (bmcc72)
thanks for the help
at least i have gotten a couple helpful posts.
ill have to try that this weekend i guess
thanks
sunnyd_206
Aug 25, 2009 07:56 PM
eric416
Oct 9, 2008 04:05 PM
Tegraracer90
Sep 26, 2008 05:22 PM
jmai86
Jul 2, 2007 01:29 AM
JAME CHANOBI
Mar 6, 2002 09:06 PM
