problem with da
Old Jul 27, 2005 | 09:46 PM
sexyblack93lude's Avatar
Default problem with da
yeah so the other da my 91 integra ls decieded to not start got fuel but no spark, just figure it was cap and rotor or coil something simple. replaced those still wouldnt start. checked all grounds good. so no im thinking starter but i doubt it. compression is good all the way through, im also thinking timing maybe? but it wouldnt just stop running one day cause of this. i dont anythin else i could check would be great anything cause im out of ideas anyone run into something similar to this before
Old Jul 27, 2005 | 09:50 PM
Naruto's Avatar
Default Re: problem with da (sexyblack93lude)
does it have like...an external coil kit? If so...try making sure ALL wires are plugged in all the way. If not....do you know how to test your spark plugs? Try that, and if that ain't it....try replacing the plug wires. If all else fails....try another ecu That would be my guesses since I've gone through similar problems.
Old Jul 27, 2005 | 10:04 PM
oldtegskoo90's Avatar
Default Re: problem with da (psychoticmindset)
yea bro, does it sound like it wanna start and it doesnt, or do the starter then click or anything? u gotta be more specific. the last time i had fuel and no spark, my wires where fucked, and the plugs where fouled out. you should try those first, and if not those, then check your ignition control module, thats located inside your distribitor, and coil. keep me posted, ill keep this on watch till u figure it out.
-Mondo
Old Jul 28, 2005 | 08:14 AM
Default Re: problem with da (oldtegskoo90)
yeah i already replaced my spark plugs and plug wires it kinda of cranks but doesnt turn over, it doesnt crack very freely, if it was my ecu i wouldnt be getting fuel would i? think i need to replace my whole dizzy if u can think of anything else let me know thanks
Old Jul 28, 2005 | 09:52 AM
Tim2179's Avatar
eight equals equals equals D
Community Builder
Loved
Could be your Diz. If your starter was bad, the car wouldn't turn over at all, as nothing would happen when you turned the key.
When my diz died, I was driving and the car just cut-off. Tried what you did, replaced the cap, rotor, plugs and wires, but that didn't help. Got a diz off http://www.car-part.com for $75 and the car ran fine.
Old Jul 28, 2005 | 04:57 PM
Naruto's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sexyblack93lude &raquo;</TD></TR><TR><TD CLASS="quote">if it was my ecu i wouldnt be getting fuel would i? think i need to replace my whole dizzy if u can think of anything else let me know thanks</TD></TR></TABLE>
not necessarily. I had a fried ECU and didn't know about it. Got fuel....got no spark in one cylinder but the rest I did. Out of sheer curiosity, I got another ECU...tried that and the car started But yea...try another diz and if that don't work ( I think it should ) try to borrow an ECU from someone who has a similar car.
Old Jul 28, 2005 | 04:59 PM
emissionsux's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sexyblack93lude &raquo;</TD></TR><TR><TD CLASS="quote">yeah i already replaced my spark plugs and plug wires it kinda of cranks but doesnt turn over, it doesnt crack very freely, if it was my ecu i wouldnt be getting fuel would i? think i need to replace my whole dizzy if u can think of anything else let me know thanks</TD></TR></TABLE>
Doesn't crank freely? Like is locks and spins again?
Old Jul 28, 2005 | 05:15 PM
Default Re: problem with da (emissionsux)
it kinda of cracks and stops and makes big werid noise then it startes to crank again
Old Jul 28, 2005 | 05:36 PM
MR-MUGEN's Avatar
charge the battery
Old Jul 29, 2005 | 08:01 AM
Default Re: problem with da (jdm92daintegra)
battery is brand new and has a full charge
Old Jul 29, 2005 | 02:52 PM
well the igntion control module, when it goes bad, your car wont start. and also the coil
Old Jul 30, 2005 | 09:54 AM
trying a new dizzy today let you know if that works
Old Aug 3, 2005 | 03:15 PM
**** guys new dizzy didnt work same **** i didnt put any of my new parts in bu i dont know im gonna try that next i dont know what the **** is goin on stgarting to get mad lol anything else i could double check would be great
Old Aug 3, 2005 | 11:31 PM
JDM INSPIRED's Avatar
is your timing belt snap???
Old Aug 4, 2005 | 06:39 AM
Default Re: problem with da (HELLA JDM)
nope brand new too
Old Aug 4, 2005 | 06:57 AM
ecks_fourttwo's Avatar
im having almost the same problem with my dc...i just found the problem yesterday afternoon...my problem was that one of the wires from the distributor was loose and falling out...it made contact once and a while(which explains the sudden shutdown of my engine while driving!) it could be something as little as that.
Old Aug 4, 2005 | 06:59 AM
Tim2179's Avatar
Community Builder
Loved
What have you replaced on the car since it stopped starting?
Have you gotten the car to start since adding any new parts? Have they made any difference at all?
Old Aug 4, 2005 | 11:06 AM
Default Re: problem with da (Tim2179)
i have replaced cap rotor dizzy coil spark plugs and wires checked its the same as it sarted fuel but no spark
im getting pissed off and about to bring it in somewhere so if u guys could help me out and same me some money that would be awesome
thanks
Old Aug 4, 2005 | 11:22 AM
Sam92Teg's Avatar
Bad / loose connections to the starter / battery or grounds can cause what you describe.
Old Aug 4, 2005 | 11:30 AM
temp's Avatar
Default Re: problem with da (Sam92Teg)
ignition switch
PaulMc
Mar 7, 2013 08:01 PM
LMdb2teggy
May 24, 2010 12:29 PM
trevorjohn88ef
Oct 20, 2007 06:55 PM
QUAIJAI
Jan 27, 2005 04:12 PM
brinks
Oct 2, 2001 01:57 PM
