problem with ctr cams
Old Sep 10, 2001 | 11:36 AM
teg1.6's Avatar
New User
Default problem with ctr cams
Two weeks ago, I installed CTR cams in my B16A first generation swapped in my 1991 integra. The problem is when the V-TEC engage at 4800 rpm you only hear the AEM scream but nothing happens. I really think it's a fuel problem because my air fuel gauge doesn't go in the "rich" like before. I try fuel preesure reg, cam gear and modified ECU who gives more fuel. Can I do something with this?
Old Sep 10, 2001 | 01:21 PM
GTEater's Avatar
Default Re: problem with ctr cams (teg1.6)
you need more fuel and to raise the vtec x-over......i just put them in my gsr and raised the vtec point to 5.2k and raised my fuel pressure.........TypeC on this board has had these cams in his ls/vtec setup, type r motor, and 97 gsr motor and the cams bogged in everyone.......the main problem was the vtec x-over more than the fuel
Old Sep 13, 2001 | 06:27 PM
905_S2K's Avatar
New User
It is your x-over point. It's way too low. You should not engage vtec too low on those cams only a few hundred rpm difference from stock x-over is needed otherwise u will have a big gap in power and actually lose power when u hit vtec. The easiest way to find out the best x-over point is on a dyno. But at least bump up your vtec x-over to around 5300-5500rpm.
cheers
[Modified by Mugen-EG6, 10:27 PM 9/13/2001]
FredrikL
46
Jun 19, 2008 10:27 AM
HoUTX98GSR
May 7, 2005 08:22 AM
squale
Oct 12, 2004 08:45 AM
vietshinobi
Jun 18, 2004 04:44 PM
SilverVTi
Sep 1, 2001 09:53 AM
