Problem with 4 door
Old Oct 16, 2008 | 08:10 PM
ohboitony's Avatar
Default Problem with 4 door
I just got this 4 door as a shell. I put carpet back in but it doesn't fit. I pulled it out from a 96 gsr and my car is a 98 ls. The carpet is to short. When I got my car the cut all the wires for the radio. I got another harness and connect color to color. Still not on. Plus my Clock isn't working either. I know this is little stuff to do but I kinda miss radio and cd while you drive. If they cut the cig lighter wires and the ash tray wires, does that effect the radio?
I check all fuse and wires to color. Everything is there but still no power.
Does anyone know where to get the gasket for the 4 door tail lights? I need some cause when it rains I have gallons in my trunk and its not cool at all!
Old Oct 16, 2008 | 09:46 PM
vietnamezerice's Avatar
Default Re: Problem with 4 door (ohboitony)
hmm... i believe the radio, clock, and ash tray/lighter is on the same circuit... change the fuses... sometimes fuses can go bad without actually appearing bad and use a test light
Old Oct 17, 2008 | 06:27 AM
AWD Terror's Avatar
Default Re: Problem with 4 door (vietnamezerice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietnamezerice &raquo;</TD></TR><TR><TD CLASS="quote">hmm... i believe the radio, clock, and ash tray/lighter is on the same circuit... change the fuses... sometimes fuses can go bad without actually appearing bad and use a test light</TD></TR></TABLE>
I believe you are right.
I bought my tail light seals from:
http://www.acuraautomotiveparts.org/
Old Oct 17, 2008 | 01:23 PM
Default Re: Problem with 4 door (AWD Terror)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AWD Terror &raquo;</TD></TR><TR><TD CLASS="quote">
http://www.acuraautomotiveparts.org/</TD></TR></TABLE>
thanks
Blazing angel
Audio / Security / Video
20
Jul 28, 2011 11:53 AM
ahhshietitztony
Jun 5, 2009 11:57 PM
bigkahuna123
Jul 13, 2004 05:40 PM
ninja8oi
Mar 23, 2003 03:03 PM
