PROBLEM!
Old Mar 21, 2006 | 05:17 PM
TEGGRY's Avatar
Default PROBLEM!
Alright guys, same problem again but better explanation. I have this problem for some time now. Im driving normally, normal shifting at 3 RPM. When i accelerate after hitting clutch, my car stutters for a few seconds and then goes. It has never happen to me before. Im thinking it is my clutch or tranny but im not sure. Anyone have this problem before?
Old Mar 21, 2006 | 05:22 PM
SlamminS85's Avatar
Default Re: PROBLEM! (TEGGRY)
try shifting higher than 3 rpm... maybe like 3000 RPM or more
haha
you could have clogged injectors or something that is keeping your butterflys from opening properly
Old Mar 21, 2006 | 05:27 PM
TEGGRY's Avatar
Default Re: PROBLEM! (SlamminS85)
sorry man but what do you mean exactly? clogged injectors?butterflys?
Old Mar 21, 2006 | 06:47 PM
jdm_bones's Avatar
I do believe this is a clutch problem, do you have a hard time getting in 1st gear or reverse... If so, then I do believe it maybe clutch related, if not it maybe the syncros in your transmission...
Old Mar 21, 2006 | 09:14 PM
teggy182's Avatar
Default Re: PROBLEM! (jdm_bones)
sounds like the clutch is slipping .. how many miles on it?
Old Mar 22, 2006 | 07:44 AM
TEGGRY's Avatar
Default Re: PROBLEM! (teggy182)
Its about 148000 miles. It is hard sometimes to get in first gear but reverse is not bad.
Old Mar 22, 2006 | 07:48 AM
CleanLikeJdm's Avatar
Hype-R Stalker
When you're shifting at normal, but Mostly higher rpms, Will it rev at all when in gear and just letting the clutch out?
And then grab a second or two later ?
I know thats pretty much what you said, but to get a better idea of it.
Old Mar 22, 2006 | 11:42 AM
TEGGRY's Avatar
Default Re: PROBLEM! (FlatBlackTeg)
Ok, first when i put in 1st gear and accelerate forward, its fine. But when i am shifting to second gear: clutch and release, accel forward(no clutch, just acceleratin)it stutters for few seconds and then goes normally. Happens to me in third gear too when shifting to fourth. Doesn't happen in fourth gear going 5th. Just happens to me in between going from 1 to 2nd gear and 2nd to 3rd and 3rd to 4th gear. I don't know if this helps.
Old Mar 22, 2006 | 12:16 PM
Hype-R Stalker
Is it worse at higher rpms, or all the same?
Old Mar 22, 2006 | 12:58 PM
slowly slipping away's Avatar
I had a similar problem when my clutch began to slip..and my flywheel needed to be replaced/ re-surfaced
Old Mar 22, 2006 | 12:59 PM
Solscud007's Avatar
I had this problem earlier. but it ends up that i was jsut really low on gas.
Old Mar 22, 2006 | 04:10 PM
TEGGRY's Avatar
It is only at 3 RPM, higher its ok but i don't shift higher than 3 RPm if normal driving.
Old Mar 22, 2006 | 04:12 PM
Hype-R Stalker
The clutch would have more tendency to slip at higher rpms,
not really sure since it's at lower rpms.
Either way, I'm sure it's still going to be something to do with the clutch/trans.
Old Mar 22, 2006 | 04:15 PM
TEGGRY's Avatar
I don't know what to do. Thinking about getting a new clutch but im not sure if that is the problem.
Old Mar 23, 2006 | 09:18 AM
Hype-R Stalker
Crack it open, only way to find out.
Old Mar 23, 2006 | 09:23 AM
RaceMyGhost's Avatar
check your air filter first of all, might be dirty as hell, second, could be your fuel injectors (pour some fuel injector cleaner stuff and put in 91 octance this time if you dont usually) third, you might just need a tune up (spark plugs, wires, etc....)
Old Mar 23, 2006 | 09:47 AM
djtsmith007's Avatar
Default Re: PROBLEM! (RaceMyGhost)
Also check your ignition for any wire nicks etc, and if you have the bolt on the clutch pedal set too low it can cause this. I learned that myself after having adjusting mine, and it did this, so i backed it off a lil bit and it works just fine.
Old Mar 24, 2006 | 04:21 AM
TEGGRY's Avatar
Default Re: PROBLEM! (djtsmith007)
THanks guys for the help. I will check all these things and let you guys know.
jdmcivic1
Oct 30, 2009 04:51 PM
iheartmygsr
Transmission & Drivetrain
Sep 29, 2008 03:53 PM
mattymatt
Nov 9, 2004 09:12 AM
deejaycherub
Oct 27, 2004 03:19 PM
ijjz
Apr 14, 2003 06:08 PM
