Power steering Question
Old Aug 29, 2006 | 08:26 AM
meotch's Avatar
Default Power steering Question
I recently took off my power steering cooler so I could fit my FMIC on my DA.. I looped the powersteering lines into the proper positions minus the cooler, the turbo is not going on the car for a bit now, so im not worried about the ps/fluid boiling, my concern is wether or not I have to bleed the powersteering b/c of the fluid that drained while I removed the cooler?
thanks,
mitch
Old Aug 29, 2006 | 08:38 AM
Lewie's Avatar
I'm here for the gangbang!
Default Re: Power steering Question (meotch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meotch &raquo;</TD></TR><TR><TD CLASS="quote">I recently took off my power steering cooler so I could fit my FMIC on my DA.. I looped the powersteering lines into the proper positions minus the cooler, the turbo is not going on the car for a bit now, so im not worried about the ps/fluid boiling, my concern is wether or not I have to bleed the powersteering b/c of the fluid that drained while I removed the cooler?
It would probably help to make sure there is no air in the lines.
Old Dec 22, 2006 | 09:40 AM
mc-integra111's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meotch &raquo;</TD></TR><TR><TD CLASS="quote">I looped the power steering lines into the proper positions minus the cooler, </TD></TR></TABLE>
Have you used this for a while? Have you had any problems without the cooler? I am thinking about doing this, but don't know if I will hurt the P/S system. My car is a track only car (higher engine speeds) so maybe the fluid will get hotter than a street application. Anybody else have any input?
Thanks
Old Dec 22, 2006 | 09:42 AM
poison's Avatar
I would just have the cap off, and have someone turn the steering wheel full turns left and right and make sure all the air bubbles come out.
egmatt93
11
Mar 10, 2007 09:35 AM
hungtat
Oct 19, 2006 12:33 PM
99delsol
Oct 9, 2006 10:22 PM
old_school_dohcvtec
Jan 18, 2006 03:23 AM
nek0
Sep 25, 2003 08:06 AM
