power steering problem
Old May 7, 2007 | 05:42 PM
JDMmovement's Avatar
Default power steering problem
i think i got this problem with my steering. my friend and i both have a 2001 integra ls, but when i drive his car, his steering is much lighter than mines and you palm it just fine (he didnt do anything to the car yet). when i turn the steering wheel in my car, its hard to turn and kinda hard to palm.
also, when i hit around 80mph, the steering wheel starts to shake. anyone know the problem?
Old May 7, 2007 | 06:24 PM
Sumslapper's Avatar
Year 3030
Default Re: power steering problem (JDMmovement)
do you have power steering fluid in the resivoir? check for pinched lines, leaks, loose belt etc...
Old May 7, 2007 | 06:29 PM
Vtec_Dude's Avatar
do you have any suspension mods? try to get alignment. I had similar problems, then i got my alignment done and everything turned out good and even better.
Old May 7, 2007 | 07:08 PM
adnmoh1's Avatar
alignment bar none
Old May 7, 2007 | 07:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sumslapper &raquo;</TD></TR><TR><TD CLASS="quote">do you have power steering fluid in the resivoir? check for pinched lines, leaks, loose belt etc...</TD></TR></TABLE>
ill check tomorrow before i head off to school or after. well no leak as far as i know of because the last leak i had was from my coolant, but i got that fixed so no leaks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtec_Dude &raquo;</TD></TR><TR><TD CLASS="quote">do you have any suspension mods? try to get alignment. I had similar problems, then i got my alignment done and everything turned out good and even better.</TD></TR></TABLE>
no suspension mods (yet), but i dont think the guy before me got an alignment because it kinda turns towards the right.
Modified by JDMmovement at 9:42 PM 5/7/2007
Old May 7, 2007 | 08:19 PM
deadline's Avatar
what size tires are u rolling on ? do u have p/s , with the belt on it ?
Old May 7, 2007 | 08:44 PM
Default Re: (deadline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deadline &raquo;</TD></TR><TR><TD CLASS="quote">what size tires are u rolling on ? do u have p/s , with the belt on it ?</TD></TR></TABLE>
iono..it came with the car but it was the same with steels. where do u find out where the belt is?
Old May 8, 2007 | 03:36 PM
Default Re: (JDMmovement)
bump for help
Ventolin
May 14, 2008 11:45 AM
Creep
Jan 29, 2003 11:47 AM
