power steering
Old Apr 24, 2012 | 03:47 PM
ZombiePharoh's Avatar
Default power steering
so my pressure hose is leaking, and i want to take the belt off so the pump isnt running and causing fluid to go everywhere until i replace the hose. is that gonna hurt anything besides making it real hard to turn the wheel? also i have thought of doing a pump delete, and was wondering what type of manual steering box i could use on my 1992 GS-R.
Old Apr 24, 2012 | 06:08 PM
JustDoingMe's Avatar
Default Re: power steering
I'm not too sure but i think you would have to take the whole pump out. I could be wrong.
Also the wheels not too hard to turn without ps but parallel parking is a little difficult if you got no muscles. lol
Old Apr 24, 2012 | 06:12 PM
b20bFourDoorCivicLX's Avatar
my teg, has no p/s or a/c, everything was deleted, and its easy as****.
Old Apr 24, 2012 | 06:18 PM
tech6923's Avatar
i think the civic steering gear box may work.
Old Apr 24, 2012 | 07:18 PM
im probly gonna leave the stock steering box if it wont get messed up.
Old Apr 24, 2012 | 07:54 PM
kchungb17a's Avatar
It will probably be harder to turn than a regular manual rack since you are pushing fluid through the pump.
You will push fluid back into the reservoir too, which will cause it to overflow and push fluid through the cap.
Overall, not the best answer to your problem. I'd just run it with the belt until you can get the hose fixed. Make sure you wipe any fluid off any painted surfaces, just in case.
Old Apr 25, 2012 | 01:24 AM
grjr's Avatar
You are not going to ruin anything by simply removing the belt. You will make the steering more difficult and it could cause you to have an accident if you can't steer the car quickly enough. Don't endanger other people on the road.
tobytigger
Nov 7, 2015 07:44 PM
NightHawk92
Sep 4, 2014 10:26 AM
safety1910
Aug 13, 2011 04:58 PM
NineT1Lude
Feb 6, 2009 11:22 PM
cd6SiR
Apr 20, 2005 07:13 AM
