Power locks
Old Jun 27, 2009 | 04:33 PM
w8inline's Avatar
Default Power locks
I have a 95 Integra Gs-R im trying to fix all the things wrong with this project but the power locks and leaks keep stressing me out First the locks i opened the door panels found the grounds were cut fix that (locks were working kind of good) now power locks will only open the doors not lock them from both driver and passenger side cant figure it out any help.
Second the leaks i have a dc2 and were i live it rains quite a bit tryed to figure this one out but it still keeps leaking i could make a fish pond out of my trunk any help again Thanks in advance
Old Jun 27, 2009 | 04:35 PM
Spawne32's Avatar
Default Re: Power locks
tailight gaskets for the leak and or weather strip around the trunk, i got all new weatherstrip for my doors because they are torn up for 80 bucks from rockauto.com
Old Jun 27, 2009 | 04:41 PM
w8inline's Avatar
sounds good buying a new set of taillights hopefully that works ill put new gaskets and check again
Spawne 32: The gaskets you bought are for all the doors or just the trunk
What about the antenna did anyone have a problem leaking from there
Old Jun 27, 2009 | 04:44 PM
Spawne32's Avatar
its possible its leaking from the antenna if the gasket is bad around the base, i bought a shark attack 2 antenna the other day from Lo custom, as far as the weather strip, it was for both doors left and right in the front of the car, the hatch gasket was seperate and i believe it was 30 dollars. Just look in rockautos catalog on their site.
Spawne32's Avatar
this should help
http://forums.nonewbs.com/showthread.php?t=158696
Old Jun 27, 2009 | 04:45 PM
w8inline's Avatar
thanks alot
Old Jun 27, 2009 | 06:50 PM
w8inline's Avatar
heres a couple more if anyone could help out my abs light is on im hearing from some friends that the abs could get alittle pricey if i just wanted to take out the whole abs system would that be a problem
also my driver window wont go up it goes down but wont come up beside the switch being no good is there anything else
Old Jun 27, 2009 | 06:59 PM
Spawne32's Avatar
grab your self a haynes manual at your local auto parts store, it has the procedures for diagnosing abs problems, the abs is controled by a computer so there are diagnostic codes you can pull. That will tell you the specific problem with the abs system.
Old Jun 27, 2009 | 07:03 PM
w8inline's Avatar
would it be a problem just to take it out make the engine bay alittle cleaner looking
Spawne32's Avatar
it would be a pain, the abs system isnt just connected to the master cylinder, its integrated into the brake system as well. Personally i like having abs.
Old Jun 27, 2009 | 07:05 PM
w8inline's Avatar
ill take a look check the codes thanks
hondamom12107
Feb 22, 2015 06:20 AM
94_CRVtec
Apr 11, 2005 12:50 AM
