Possible piston ring problem?
Old Sep 1, 2003 | 11:14 AM
Mark's Avatar
*Bounty Hunter*
Default Possible piston ring problem?
For the past 2 weeks almost, my car has smelled like its burning a vicious oil.
Ive checked my air filter (stock airbox) and there doesnt seem to be a trace of oil in there.
I checked to see if there was any coolant in the oil or vice versa, which my friend told me could lead to a possible head gasket problem.
The car lets out a light blue smoke, but only once in a while, and when I "step" on it, it lets out a "puff" of this light blue stuff :/
Also, it smells awfully bad inside when I drive it around daily...which leads me to strongly beleive the rings are shot...
Which leads me to my uber-rebuild, which is gona cost about 4k muahaha..
Any suggestions on if my rings are dead, before I spend a crap load of money on my car?
Old Sep 1, 2003 | 12:12 PM
Mark's Avatar
*Bounty Hunter*
Default Re: Possible piston ring problem? (94BlackCivicEX)
bump
Old Sep 1, 2003 | 06:48 PM
91tegrals's Avatar
do a compression test does youre idle stumble at all could be any little sensor or maybe a bad cat..
Old Sep 1, 2003 | 10:49 PM
Mark's Avatar
*Bounty Hunter*
Default Re: (91tegrals)
My constant idle sits at 450-500 RPMs :/
Ill check out the compression tmrw.
Old Sep 2, 2003 | 06:56 AM
jimc93si's Avatar
I agree with the bad cat theory. If the inside of your car smells you have something wrong with the exhaust system, most likely the cat. Check the gaskets at the cat. Check the exhaust header isn't cracked and the gasket there too. When was the last time the valves were adjusted?
If your rings were bad you would have blue smoke more often plus, you really have to drive the **** out of a Honda engine to make the rings fail. One thing Honda Does know about is piston rings.
Old Sep 2, 2003 | 06:59 AM
Rory Breaker's Avatar
Default Re: Possible piston ring problem? (jimc93si)
Do a leakdown test to determine if your rings are bad. Im not sure if there are any how-tos on this, but a tester should be available at your local parts store.
Old Sep 2, 2003 | 09:15 AM
91tegrals's Avatar
i doubt its youre rings but possible,if it is youre cat you should get a smell like rotten eggs or a bad fart in youre car...
Old Sep 2, 2003 | 08:59 PM
Mark's Avatar
*Bounty Hunter*
Na it smells more like burning oil...Im gona do some wicked extensive maitenance on the car this week.
I plan on rebuilding and making the block bulletproof. If you boost, might as well boost high, eh commrades?
Bigoc1655
Aug 17, 2015 09:01 AM
dlstech
Mar 8, 2012 05:15 AM
egcoupe007
Jul 6, 2011 06:47 AM
tianporn
10
Jul 20, 2004 11:24 AM
JSpecwest
Aug 10, 2001 08:37 AM
