Possible alternator issues.
Old Aug 6, 2011 | 05:45 PM
CompanyFlow's Avatar
Default Possible alternator issues.
So I'm in a bit of a predicament here. As I was driving, I decided to use my AC and a few minutes later my radio shut off and restarted over and over, but would restart and stay on when the AC compressor wasn't running. I believed the alternator to be bad, tested it with an analog meter that read 10.5ish volts and replaced it with one I had available to me. The replacement only read 9 volts but I had no choice but to drive it home. As I drove it, the typical symptoms of a bad alternator came up (fading indicators, clock shuts off, tach goes haywire, hesitation in acceleration) and suddenly everything worked perfectly the second I got off of the freeway. This was about a week ago, and today the same old crap happened again, only this time nothing works. I removed the alternator and took both of them to Autozone to have them tested, and surprisingly both of them passed. I'm going to clean all of the grounds and connections with a wire brush tomorrow and install one to see if it works, otherwise I'm going to have one rebuilt for me. I'm at my wits end. Does anyone have any ideas what else it could be?
Old Aug 6, 2011 | 07:18 PM
Spawne32's Avatar
Default Re: Possible alternator issues.
Thats a bad battery if ive ever seen one.
Old Aug 6, 2011 | 10:05 PM
98bucket's Avatar
Yup^ exact thing happen to me on Monday battery was gone, couldnt even charge it. The radio would turn off and everything changed the battery and the car was still acting up for about a day and a half. But its better now.
Old Aug 7, 2011 | 01:07 PM
Hidenplanvew's Avatar
Just replace both and replace the easy grounds
Old Aug 12, 2011 | 10:29 AM
jimburt3rd's Avatar
same thing happened to me but about 30 minutes after the radio and dash went nuts my car died on me so i got it towed it was one of my 02 sensors shorted out and was causing the car to shut off. or should i say a wire conected to the 02 sensor was shorting out lol
Old Aug 12, 2011 | 10:58 AM
Spawne32's Avatar
doesnt make sense at all, your o2 sensor is fused so that cant happen
Old Aug 13, 2011 | 08:59 PM
I got them both tested at Autozone and they both passed. I installed one of them resulting in the same problem. It ended up being a loose ground to the negative terminal in the fuse box, but I feel this happened because I relocated my negative terminal so that I could use a different battery.
mistakesmade
Honda Civic (2001 - 2005)
Jul 31, 2018 10:33 PM
B18CYAAA
Aug 11, 2009 08:16 PM
busyychild
Feb 8, 2008 07:08 PM
92silude
Jun 14, 2005 12:11 PM
BlackOut21
May 9, 2005 02:56 PM
