popping code p1399
Old May 10, 2007 | 09:17 AM
donvito#1's Avatar
Default popping code p1399
any know what that is i looked at the form and their is no listing for it but it is in the vtec section? https://honda-tech.com/zerothread?id=978933 their what i looked at
Old May 10, 2007 | 09:25 AM
donvito#1's Avatar
Default Re: popping code p1399 (donvito#1)
just did some rescearch and what i found was a multi cyclinder misfire is that right
Old May 10, 2007 | 09:26 AM
GserpleaSR's Avatar
What Car? Year?
Old May 10, 2007 | 09:30 AM
donvito#1's Avatar
Default Re: popping code p1399 (GserpleaSR)
2000 integra gsr
Old May 10, 2007 | 09:44 AM
donvito#1's Avatar
any one does it have to do with a multiple cylinder misfire help 2000 teg gsr
Old May 10, 2007 | 09:50 AM
GserpleaSR's Avatar
could not find it! sure its the correct code?
Old May 10, 2007 | 12:22 PM
thewrai6th's Avatar
Thats the right code, it comes along with p0300 p0301 p0302, p0303, etc...
You may have a vacuum leak, a bad tune, bad injectors, bad plugs, or 1000 other things.
Any other codes?
I got this code recently after installing the turbo, but after resetting the ecu and calibrating the wideband, the code went away for good. It was a problem with the fuel trim and I was leaning out badly during idle-warmup.
Old May 10, 2007 | 12:51 PM
donvito#1's Avatar
Default Re: popping code p1399 (thewrai6th)
just had injectors replaced plugs replaced wires replaced cap and rotor replaced both o2 r bad could that be the problem replacing o2 this weekend
Old May 10, 2007 | 01:30 PM
thewrai6th's Avatar
Only your primary O2 controls the fuel trim, the secondary only throws CELs for bad cat.
Old May 10, 2007 | 03:04 PM
GserpleaSR's Avatar
Where did you get that p1399 comes with random misfire?? I have ALLDATA and Mitchell On Demand and none of them have it? just wondering.
Old May 10, 2007 | 03:15 PM
thewrai6th's Avatar
I just knew it from memory but here is some data:
P0301- Cylinder 1 misfiring
P0302- cylinder 2 misfiring
P0303- cylinder 3 misfiring
P0300- random / multiple misfire detected.
P1399- Manufactures control Ignition system OR Misfire
I think p1 codes are mfgr specific and don't always show up in OBD2 code lists.
Old May 10, 2007 | 03:24 PM
GserpleaSR's Avatar
Where did you get your info. from? wondering?Thank's
Old May 10, 2007 | 03:30 PM
thewrai6th's Avatar
well, from memory... (I had to figure it out myself) but I found that info on this site also. Here's one link:
https://honda-tech.com/zerothread?id=796378
Old May 10, 2007 | 03:35 PM
thewrai6th's Avatar
One more bit of info, p1399 does not throw a CEL (at least at first it doesn't), the P03XX codes throw the CEL.
Old May 10, 2007 | 03:40 PM
GserpleaSR's Avatar
Ohhhhhhhh... ok, but the info you got is from a different motor. He even wrote that he is not sure what ECU he has! All ECU's are different. Iam sure he is wrong.
Old May 10, 2007 | 03:48 PM
GserpleaSR's Avatar
Well thanks for the info. but iam sure that code does no exist atleast on a 2000 acura integra! Thanks again.
Old May 10, 2007 | 03:58 PM
thewrai6th's Avatar
Actually, this was on my 2000 GSR. The mysterious p1399 code is a REAL code... random misfire. Simple as that, it's a mfgr specific OBD2 code.
I can guarantee this as 100% fact, as I pulled it myself from my 2000 GSR with my code reader.
Old May 10, 2007 | 05:24 PM
thewrai6th's Avatar
The shop manual says look for the other codes. If there are any, troubleshoot them first as they are probably the cause of the misfire. If not,
http://www.hondahookup.com Get the manual Chapter 11
Honestly, if it's a pending p1399 code and you don't have a p030X or CEL, then it was probably some bad gas.
Old May 11, 2007 | 05:20 PM
donvito#1's Avatar
yeah getting some mis fire weird though i just replaced the wires with bosch cap rotor and spark plug i was told bosh was junk and i wasted my money im just going to buy a new disturbuter and some ngk wires and if that dont fix it i dont know because i just replaced the injectors and fuel filter thanks
Old Oct 30, 2007 | 02:00 PM
all-mtr-teg's Avatar
Any update, im getting the same 0301, 0303, 1300 and 1399 codes
Old Dec 11, 2007 | 06:30 PM
preludepower420's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GserpleaSR &raquo;</TD></TR><TR><TD CLASS="quote">Ohhhhhhhh... ok, but the info you got is from a different motor. He even wrote that he is not sure what ECU he has! All ECU's are different. Iam sure he is wrong.</TD></TR></TABLE>
All OBDII is the Same
Old Dec 21, 2016 | 04:35 AM
Andrew Swick's Avatar
I have a 2000 LS inegra b18b1 engine throwing the p1399 code picture proof for those of youbthatvsay this code dose not exsit on a 2000 integra.
Old Dec 22, 2016 | 07:00 PM
wunfstgsr's Avatar
Loved
Community Favorite
I was getting that code with my 98 LS replaced the cap rotor and wires and code has not come back.
xtegx
Mar 19, 2010 12:39 PM
civy123
Sep 6, 2009 08:41 PM
dah99si
May 14, 2009 09:47 AM
EJ ITO
Feb 28, 2007 05:56 AM
EFb18b
Sep 17, 2005 07:30 PM
