Poor Mans Type R...
Old Aug 20, 2004 | 08:35 AM
bk92teg's Avatar
Default Poor Mans Type R...
Ok guys I dont know how familiar you are with this but the other day I was talking to a friend and I told him that I would be having a B17A1 block, with a B16 (99-00Si) Head. He loks at me and says "Wow, poor mans Type R..." What does this mean? I asked another guy about it and he says that its a "poor mans type r" if it were a B18 block?? Has anyone ever heard of this at all??
Brian
Old Aug 20, 2004 | 08:53 AM
ApexOne's Avatar
Default Re: Poor Mans Type R... (bk92teg)
You have a b17 without a vtec head on it? or did you get just the bottom end?
Old Aug 20, 2004 | 09:02 AM
pirate252's Avatar
He said that because its like a type r, but not quite, the only differences i can think of are...
Type R head has mild port and polish, yours doesnt
Type R head has dual valvesprings, your doesnt
Type R block has .1L more displacment than yours
Type R block has slightly higher compression pistons than yours
I think the valves may be bigger, but i cant remember, i dont think so though.
Your making a hybrid motor, the most famous ones for integras are ls/vtecs (b18 block and b17/16 head) And a CRVTEC (b20 block and b17/16 head)
Thats why he is calling it the poor mans tpye R, its almost like the b18c5, but not quite :D
Old Aug 20, 2004 | 09:13 AM
JimBlake's Avatar
Default Re: Poor Mans Type R... (pirate252)
Springs, shocks, & anti-roll bars; & the chassis of a real type R has some strengthened components.
Oh wait... If it's going in a '92 body, that doesn't even make sense.
Old Aug 20, 2004 | 09:20 AM
bk92teg's Avatar
Default Re: Poor Mans Type R... (ApexOne)
No I have a B17A1 Block, with a B16 (99-00SI) VTEC head on it.
Brian
Old Aug 20, 2004 | 09:21 AM
bk92teg's Avatar
What makes it almost like a B18C5??? Does it still work on the B17 block though??? Is it going to be a pretty strong motor, powerwise????
Brian
Old Aug 20, 2004 | 09:27 AM
NuclearB18B's Avatar
he doesn't know what he's talking about.
Old Aug 20, 2004 | 09:33 AM
YumVTEC's Avatar
Default Re: Poor Mans Type R... (ha illuminato un)
poor man's ITR motor = b18c1 gs-r block and crank, ITR pistons, b16a head with ITR cams & intake manifold.
Old Aug 20, 2004 | 10:03 AM
vtec69's Avatar
Default Re: Poor Mans Type R... (YumVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YumVTEC &raquo;</TD></TR><TR><TD CLASS="quote">poor man's ITR motor = b18c1 gs-r block and crank, ITR pistons, b16a head with ITR cams & intake manifold.</TD></TR></TABLE>
yeah thats what I thought /\/\/\/\
Old Aug 20, 2004 | 10:32 AM
3.504's Avatar
Default Re: Poor Mans Type R... (vtec69)
p72 block, pr3 top. ITR internals. port work and aebs or similar replica ITR cast mani, JDM ITR 4-1, b16 trans (i know its not similar, but its better than the gsr's... the ITR has longer gears than a b16, but shorter than a gsr). chipped p28 w/ ITR like program... maybe a bit more aggressive.
thats about as close as you'll get to a real b18cR besides the serial numbers and block stamping. all that will end up costing more to do (if you buy the p72 block, you dont just have one in your gsr that you're trying to convert) than what it would be to buy an ITR swap from one of the jdm junkyards.
b17= pr3 block, not even close to ITR. b17 comes w/ pr3 head, the 99-00 si is a pr3 head. ITR/CTR's come w/ pr3 heads, but they're hand ported and have beefier internals.
Old Aug 20, 2004 | 10:51 AM
Cliffjumper2's Avatar
Default Re: Poor Mans Type R... (3.504)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3.504 &raquo;</TD></TR><TR><TD CLASS="quote">p72 block, pr3 top. ITR internals. port work and aebs or similar replica ITR cast mani, JDM ITR 4-1, b16 trans (i know its not similar, but its better than the gsr's... the ITR has longer gears than a b16, but shorter than a gsr). chipped p28 w/ ITR like program... maybe a bit more aggressive.
b17= pr3 block, not even close to ITR. b17 comes w/ pr3 head, the 99-00 si is a pr3 head. ITR/CTR's come w/ pr3 heads, but they're hand ported and have beefier internals.</TD></TR></TABLE>
so then that would be a Rich man's typeR motor
why not call the b16 swap bored out to 1.8 a poor man's typeR........just wondering?
I mean to qualify as the poor mans version of anything, shouldn't it cost half as much.
Old Aug 20, 2004 | 11:32 AM
arw321's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3.504 &raquo;</TD></TR><TR><TD CLASS="quote">, b16 trans (i know its not similar, but its better than the gsr's... the ITR has longer gears than a b16, but shorter than a gsr). .</TD></TR></TABLE>
Actually the b16 tranny (I'm assuming you mean the usdm Si) has the same gear ratios as the ITR tranny. ITR tranny has LSD, b16 does not.
Old Aug 20, 2004 | 11:45 AM
93GSRB17's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bk92teg &raquo;</TD></TR><TR><TD CLASS="quote">Ok guys I dont know how familiar you are with this but the other day I was talking to a friend and I told him that I would be having a B17A1 block, with a B16 (99-00Si) Head. He loks at me and says "Wow, poor mans Type R..." What does this mean? I asked another guy about it and he says that its a "poor mans type r" if it were a B18 block?? Has anyone ever heard of this at all??
Brian</TD></TR></TABLE>
If I were to do my rebuild over I would use a B20 with my B17. mmm 2.0 L
Old Aug 20, 2004 | 11:58 AM
furious94ls's Avatar
Default Re: Poor Mans Type R... (93GSRB17)
Should have gotten the S2k bottom end with the NSX head.
Old Aug 20, 2004 | 12:16 PM
simon98h22's Avatar
Default Re: Poor Mans Type R... (furious94ls)
Hey as long as we're dreaming:
K24 Bottom with a K20A2 head
Mmmmmmmmmmmmm 2.4 litre
Old Aug 20, 2004 | 12:19 PM
simon98h22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by furious94ls &raquo;</TD></TR><TR><TD CLASS="quote">Should have gotten the S2k bottom end with the NSX head.</TD></TR></TABLE>
Why would you want to have a 2.0 litre bottom end that dishes out a whopping 153 ft/lbs of torque!?
Old Aug 20, 2004 | 01:34 PM
patmcd's Avatar
Default Re: Poor Mans Type R... (simon98h22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by simon98h22 &raquo;</TD></TR><TR><TD CLASS="quote">
Why would you want to have a 2.0 litre bottom end that dishes out a whopping 153 ft/lbs of torque!?</TD></TR></TABLE>
I think he was kidding.
Old Aug 20, 2004 | 01:43 PM
G1 TEGGY's Avatar
Default Re: Poor Mans Type R... (patmcd)
or just slap a chevy big block in a CRX
Old Aug 20, 2004 | 02:40 PM
Default Re: Poor Mans Type R... (G1_TEGGY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G1_TEGGY &raquo;</TD></TR><TR><TD CLASS="quote">or just slap a chevy big block in a CRX </TD></TR></TABLE>
haha, but I've actually read of someone putting a small block into a rex......lots of fabricating
Old Aug 20, 2004 | 05:41 PM
Dent Free's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by simon98h22 &raquo;</TD></TR><TR><TD CLASS="quote">Hey as long as we're dreaming:
Mmmmmmmmmmmmm 2.4 litre </TD></TR></TABLE>
Well . . .
Its better if you . .
TSX Block ---high c/r
RSX --- Well balanced head with intake + exhaust valve timing
JDM Integra R --- trans . . "if not the RSX will do"
Put this into a 92 CX hatch and you should hit low 13 with a bad driver
put a 75 shot on and you have 11's
Anyone could make and crotch rocket killer with this combo
Do you believe ? ? ?
Old Aug 20, 2004 | 08:32 PM
darrinbrewer's Avatar
i'm damn close!
gsr block/crank/rods
ITR pistons
gsr head with itr outer springs/portflow inners(gsr head makes more compression)
ferrea stock replacement size valves
ITR cams
skunk2 manifold
CTR LSD Tranny
itr cams are coming out in a few days..skunk2 stg 1's going in
TEGGRY
Dec 29, 2005 09:30 AM
whiskeydicks45
Dec 23, 2005 12:36 PM
DriveSlowHomie
Sep 27, 2004 12:17 PM
RacnGSR
Aug 14, 2002 08:38 PM
