Please help! car is stranded....
Old Oct 22, 2009 | 06:34 AM
fourdoorteg's Avatar
Icon3 Please help! car is stranded....
I have a 91 integra 4 door and out of the blue after trying to accelerate at a light, The car just sputters likes its going to shut off for a few moments then actually dies.
It would not start period after that. My and my friend bought some starter fluid which caused the car to start.
So im assuming its the fuel pump or the filter?? i dont know. What is the best way to test? How easy is it to replace the pump. IDK please help. thanks joel
Old Oct 22, 2009 | 08:12 AM
Default Re: Please help! car is stranded....
bump please help!
Old Oct 22, 2009 | 08:33 AM
follie gatts's Avatar
i think you have to drop the tank to replace a DA fuel pump. does it push fuel to the filter when you turn the key on?
Old Oct 22, 2009 | 09:12 AM
hybrid90's Avatar
Igniter or distributor? Are you getting any spark from the plugs?
Old Oct 22, 2009 | 10:34 AM
How do i check that exactly?
and im assuming that i have spark because it turned over when i used starter fluid.
Old Oct 22, 2009 | 01:47 PM
ok, i am a 3rd gen guy moreso than a 2nd gen.
that said, when you turn the key to the on position the fuel pump should start pushing fuel through the filter so the motor can start. if you disconnected the fuel line, it would spray out of the end of the line instead of going where it normally does. spray would confirm your fuel pump is running.
Old Oct 22, 2009 | 05:08 PM
UPDATE
So i replaced the fuel filter and it seems that the pump is ok because fuel was coming out of the lines once i replaced the filter and turned the car to the on position. I wouldnt say that it was spraying out but leaking at a fast pace. I pulled the spark plugs and two of them had oil all over it. I cleaned them and reinstalled and still the same problem. Like i said, i think its fuel related because it turned over with starter fluid. WHAT ELSE COULD IT BE?
Old Oct 22, 2009 | 06:45 PM
xiapher's Avatar
Originally Posted by fourdoorteg
UPDATE
i would check ur pgmfi relay my da i had to replace them like every 2 months(junk yard ones but ya) i had the same problem
Old Oct 23, 2009 | 08:29 AM
juevi's Avatar
Foreign Symbols
I'd probably pay to get it diagnosed. You already purchased a fuel filter, which monies could have went to diag. It's money well spent.
Old Oct 23, 2009 | 08:40 AM
TonyRomo's Avatar
I would just have it towed somewhere, although if I had to bet I would say the distributor went bad. This happened to my friend in his DC and it ended up being the ignitor as someone already mentioned.
Old Oct 23, 2009 | 10:32 AM
Sketch_hs's Avatar
Sounds like your injectors aren't firing.
If it runs at all with starter fluid, you have spark. If you have fuel pressure, the pump is good.
has to be the injectors. Check fuses, wiring, ecu.
is there power to the injectors?
BTW, you can post these kind of questions on www.driverside.com and get free help from expert mechanics. Like me :D
Old Oct 23, 2009 | 11:48 AM
sicky's Avatar
grammer nawzi
is there start on the moon?
Old Oct 23, 2009 | 12:21 PM
YeuEmMaiMai's Avatar
uhm is there a fuel pressure guage port on your fuel rail?
if so, hook up a fuel pressure guage anything above 40 should be good. also test fuel pressure regulator as it may have failed. Does the car throw any codes?
smileygreasy
15
Apr 19, 2015 07:36 PM
91_shoebox_Si
Mar 20, 2011 07:53 PM
caliek4
Jul 30, 2006 08:32 AM
CustomTeggy44
Jul 4, 2004 03:04 PM
crxxrc
Feb 8, 2004 01:39 PM
