PLEASE HELP!!!!
I disconect the negative wire from the battery and the OEM radio got BLOCKED...
then i make a research and I found the code is in the glove box... on a sticker... the last 5 numbers... but i got a number "0" how can i put this one on the code?...
PLEASE HELP...
PLEASE HELP...
call ur local honda dealer, they should be able too look it up. ive heard of some places charging but the dealership i called jus gave it to me right over the phone with jus verifying a few things like vin and such.
Pull the HU and get the serial number off the HU, go to your local Honda/Acura dealer, service dept. with proof of ownership, [registration and your drivers licence] it will only take them a min. to look up the code, it should cost you nothing, the charge is if they have to pull the HU to get the serial number, I am pretty sure it is 4 digits with no 0s, or try the 2411. 94
doesnt work ^^
Go to dealer, have serial number, proof of ownership and ID, they will give you the code number.
It is unlikely you would get that info over the phone, so go to the dealership.
Have you tried to other "hiding places", under ash tray or trunk/hatch, [between hinges]? 94
