Please help
Old Mar 24, 2009 | 03:02 PM
AcIntegra's Avatar
New User
Default Please help
I bought a 93 acura integra with a ls/vtec motor. b18a1 ls bottom end and a GSR head the car runs ok but dont have power like it should on low end or mid range.Also when vtec is ready to kick in it throws a cel for code 23 knock sensor witch i put a brand new one.I dont know what else to do.It also has a ls manifold not a gsr. somebody PLEASE HELP
Old Mar 24, 2009 | 03:12 PM
lsvtecwill's Avatar
Default Re: Please help
you bought a honda and wanted low to mid power?
I don't know what to tell you besides you must have a LS with a LS head. The intake manifolds have different bolt patterns (I assumed your talking about the intake manifold as all bseries exhaust ones fit each other and there for not relevant)
Besides all this... You bought the car this way?
Old Mar 25, 2009 | 05:42 PM
AcIntegra's Avatar
New User
no its a gsr head says p72-1 and also its DOHC vtec kicks sometime but other times it throws code 23 knock sensor it just dont feal like it got any power.
Old Mar 25, 2009 | 07:27 PM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
What LSVtecWill was trying to say is that if you really have a GSR head, then you do not have a LS intake manifold. The LS manifold cannot bolt onto a GSR because it has a different bolt pattern. Maybe you have a ITR style manifold?
Also what ecu do you have?
Did you check the wiring for the knock sensor to see if its wired correctly?
Old Mar 25, 2009 | 08:34 PM
lsvtecwill's Avatar
It sounds like a bad knock sensor (limp mode). They are just little microphones and more delicate than you might think. And where did you install the knock sensor? The LS block does not have a mounting hole.
I would also like to know what ECU.
Old Mar 26, 2009 | 04:23 AM
nsxtasy's Avatar
H-T Order of Merit
https://honda-tech.com/forums/acura-integra-6/creating-new-topic-choose-subject-specific-title-not-help-me-asap-2477272/
Old Mar 26, 2009 | 05:33 AM
seanbev24's Avatar
Haha I love when nsxtasy does that. Get more specific with the thread title.
Anyways, what ECU are you running? If it actually is a GSR head, and you say it's an "LS" manifold, chances are it's a skunk2 or blox manifold. If this is the case and you don't have a tune, it's not gonna run right.
If your car isn't tuned, I recommend chipping the ECU and tuning it on the dyno. While doing that, they can disable the knock sensor in the ecu, problem solved. Honda knock sensors are crap anyway
Old Mar 26, 2009 | 06:09 AM
sirmugenpower's Avatar
+1
xero_xero
Jun 14, 2012 06:07 PM
crxowner
Feb 22, 2006 12:12 PM
Metzler
Nov 22, 2004 07:16 PM
gregs96ls
Sep 27, 2004 11:07 AM
tegasaurus
Dec 10, 2002 07:46 AM
