please answer my ? this time
Old Jan 23, 2006 | 03:40 PM
skata89's Avatar
Default please answer my ? this time
k i ask not too long ago about if i have a type R engine in a ls is it safe to shift at 8 cuz i know the type R redlines at 8. and please no hating. all i want is a simple yes or no
Old Jan 23, 2006 | 03:44 PM
rdblckSV650S's Avatar
Default Re: please answer my ? this time (skata89)
if you have a type R motor in your car you can shift at 8400.
Do you have pictures?
loudassVTEC's Avatar
I think type R's revv to 9300 at the fuel cutoff. (someone correct me if I'm wrong). I shift my b16 @ 8400, so I don't think 8000 in a type r will hurt it at all.
Old Jan 23, 2006 | 03:45 PM
skata89's Avatar
of the motor or car?
Spectrum24x's Avatar
Default Re: please answer my ? this time (slvrblckf4i)
are you worried about the chassis or suspension components not being able to handle it or something?
Old Jan 23, 2006 | 03:47 PM
skata89's Avatar
ya. cuz i dont want anything to snap on me when im pushing it
Old Jan 23, 2006 | 03:48 PM
skata89's Avatar
Default Re: (skata89)
heres the motor
Old Jan 23, 2006 | 03:51 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: please answer my ? this time (loudassVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loudassVTEC &raquo;</TD></TR><TR><TD CLASS="quote">I think type R's revv to 9300 at the fuel cutoff. (someone correct me if I'm wrong). I shift my b16 @ 8400, so I don't think 8000 in a type r will hurt it at all.</TD></TR></TABLE>
The B18C5 ITR has a fuel cutoff at 8400RPM. You have been corrected.
Old Jan 23, 2006 | 03:52 PM
mike9571's Avatar
So your sayin you would be using the LS tranny?
Old Jan 23, 2006 | 03:54 PM
skata89's Avatar
na its a type R
Old Jan 23, 2006 | 03:59 PM
projectac's Avatar
the ground to the engine is in the wrong position.
Old Jan 23, 2006 | 04:01 PM
Johnny_Rocket's Avatar
dude, what the hell are you asking?!
Old Jan 23, 2006 | 04:06 PM
Turbo(less)DB8's Avatar
ok, why would u even do a swap if you don't know that much about it? just because it's hype r? honestly people, what happened to doing research and actually knowing what ur car can do. geez.
Old Jan 23, 2006 | 04:09 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skata89 &raquo;</TD></TR><TR><TD CLASS="quote">k i ask not too long ago about if i have a type R engine in a ls is it safe to shift at 8 cuz i know the type R redlines at 8. and please no hating. all i want is a simple yes or no</TD></TR></TABLE>
Quite simply, yes. I assume that you have a P73 ECU.
Old Jan 23, 2006 | 05:00 PM
zeroz's Avatar
Default Re: please answer my ? this time (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">
The B18C5 ITR has a fuel cutoff at 8400RPM. You have been corrected.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo(less)DB8 &raquo;</TD></TR><TR><TD CLASS="quote">ok, why would u even do a swap if you don't know that much about it? just because it's hype r? honestly people, what happened to doing research and actually knowing what ur car can do. geez.</TD></TR></TABLE>
Old Jan 23, 2006 | 06:25 PM
skata89's Avatar
i didnt do the swap. i bought the car like this. and im tryin to learn as much as i can bout it. and where is the ground soppose to be at? and the ecu say 95 civic on it. not quite sure why. maybe someone can help me out on that.o and the ecu is chipped.
Old Jan 23, 2006 | 06:32 PM
bks84's Avatar
Loved
on the side of the ecu theres a sticker, thsi sticker has some important info on it.
look for the code on the ecu, it needs to read p73 or pct
Old Jan 23, 2006 | 06:40 PM
even still, would you date a girl not knowin anything about her? props on trying to learn tho. There's a bit more info that we're gonna need to be able to help you. 1) what year is ur car, 2) what ecu is it? U mentioned that the ecu had 95 writen on it. If this is the case i'll assume its a chipped p28 and u have a 94-95 ls or a 96+ with a ecu jumper harness. Either way, u should be fine going to 8400. If the engine does indeed have hype r componets (valvetrain) u should be good to 9300. However, in stock form the c5 powerband starts to drop off past 8400 so i wouldn't go higher anyway. Just because it can go that high doesn't mean you should
Old Jan 23, 2006 | 06:46 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
what if it's a GSR head with a type r valve cover? that would suck.
Old Jan 23, 2006 | 07:05 PM
jBj's Avatar
jBj
Default Re: (^^whatnoobsearchthenGTFO)
Inspect your ecu closer and see if you can find a code. Have you tried revving past 8k rpm?
Also, check the code on the left of engine block just down from the exhuast manifold, I am now curious if it is actually a b18c5.
Old Jan 23, 2006 | 07:12 PM
weak_tec's Avatar
Default Re: (jBj)
lemme get ur motor and i'll get you an ls, that way you dont have to worry about ne thing
Old Jan 23, 2006 | 07:45 PM
Sack Master's Avatar
Default Re: (spoon_meeH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectac &raquo;</TD></TR><TR><TD CLASS="quote">the ground to the engine is in the wrong position.</TD></TR></TABLE>Would the car perform better if he moved it to the stock location?
Old Jan 23, 2006 | 08:28 PM
downsouth0's Avatar
Default Re: (Sack Master)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sack Master &raquo;</TD></TR><TR><TD CLASS="quote">Would the car perform better if he moved it to the stock location?</TD></TR></TABLE> thats funny
Old Jan 23, 2006 | 08:43 PM
zeroz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ^^whatnoobsearchthenGTFO &raquo;</TD></TR><TR><TD CLASS="quote">what if it's a GSR head with a type r valve cover? that would suck.</TD></TR></TABLE>
just check the engine code on the block to make sure
Old Jan 23, 2006 | 09:06 PM
AllMotorDan's Avatar
that valve cover deff looks painted and not like an oem itr cover
