piston replacement
Old Oct 3, 2007 | 10:11 AM
1993gsrcivic's Avatar
Default piston replacement
what stock piston will give you highest compresson in a gsr
1. type r
2. gsr
3. b16
or is it better to just go wit after market pistons
Old Oct 3, 2007 | 10:20 AM
lsBlaxican707's Avatar
Default Re: piston replacement (1993gsrcivic)
why don't you just google or looking at the service manuals or the compressions?
Old Oct 3, 2007 | 10:39 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
http://www.c-speedracing.com their CR calculator should give you the answer you need.
Old Oct 3, 2007 | 11:47 AM
myfirstdc2's Avatar
if its oem piston u want then i say pct will net the highest comp. i believe in the range of 12.5 give or take depending on your setup or what not. if u go aftermarket then u can get whatever u want to match your setup.
bradabu
Aug 12, 2011 05:18 AM
christmastree
Oct 6, 2009 07:22 PM
4thgenHB157
Nov 25, 2008 08:44 PM
H2nr
Honda S2000
May 13, 2004 07:33 PM
-16V-
Jan 26, 2003 06:46 PM
