piston question for ls/vtec
Old Aug 20, 2001 | 01:59 AM
Darren94ls's Avatar
New User
Default piston question for ls/vtec
hey everyone,
im doing an ls/vtec swap in my car and i was wondering what pistons i can use. i was planning to use the usdm type r pistons, but i saw some jdm type r pistons, i think spoon but not sure. my car is going to be a daily driver and i want a reliable set up. so any help is apperciated
thanks
Old Aug 20, 2001 | 03:51 AM
stretracr's Avatar
Default Re: piston question for ls/vtec (Darren94ls)
Get the jdm itr pistons. You will have around 11.3 or so comp (with a gsr head). You can get the spoon's but the only difference is they are balanced. If you are wanting to rev higher than @7k. Then I would think about getting a block girdle (z10 makes a nice one). good luck.
Old Aug 20, 2001 | 05:17 AM
bruthaboost's Avatar
I seriously suggest sitting down and writing down all your expected expenses. This is not as cheap an alternative as most may think. The block girdle is a good idea. You can also modify a gsr one (may preference and cheaper too).
Email me is you got any more Q's. I'm finishing mine right now.
Old Aug 20, 2001 | 09:41 AM
Integra187's Avatar
Default Re: piston question for ls/vtec (b18bpwr)
hey b18bpwr how much did u probably spend total on the lsvtec swap?
Old Aug 20, 2001 | 11:36 AM
Darren94ls's Avatar
New User
Default Re: piston question for ls/vtec (Integra187)
thanks everyone!
how much is a block girdle? and what does it do? im going to be using a 99' b16 head so will the jdm type r spoon pistons work as well?
darren
Old Aug 20, 2001 | 12:58 PM
Scorpaznatica's Avatar
New User
why not do a CRVtec swap instead?
Old Aug 20, 2001 | 01:02 PM
HX_Guy's Avatar
A block girdle is around $300 with all the parts needed I believe.
It supports the main caps so there isnt as much vibration at higher RPMs which in turn helps keep the bearings in better shape.
Honda uses a block girdle on the B18C1 and B18C5...and Im sure its not on there just for appearance...it definately is a good thinsg on motors with less then perfect R/S ratio.
yaucovtec
Mar 4, 2009 09:58 AM
GSE980
Dec 8, 2008 12:58 PM
89s1
Sep 20, 2006 06:11 PM
jamessh1
May 28, 2004 04:30 PM
flyrice
Nov 1, 2003 02:19 PM
