Piston install: process?? install fees??
Old Nov 20, 2002 | 03:51 PM
BlueTeg's Avatar
Default Piston install: process?? install fees??
I'm looking into swapping out the pistons in my LS for the b16a (SI) pistons to complement a cam upgrade that I'm planning. With the longer duration cams I'm supposed to lose some compression, I'd like to compensate for that by adding the the SI pistons which are a direct bolt in, and will raise my static compression ratio to about 11:1
I called my local tuner shop and they said that they would have to refer me to an engine shop because switching pistons requires the motor to be removed from the car. Resulting in at least a week of down time for my car. Install will be quite costly he said. He said it would almost be cheaper to just buy another LS engine....have someone install the pistons on that-to cut down on the time my car is in the shop....and that way all they have to do is just swap engines.
This seemed EXTREMELY complex for just swapping out the pistons. I understand that its not exactly a "bolt on" mod.....but I'd like to hear what some of you guys were quoted on install fees for piston swaps.....and how long it took them to do it.
Last question is: for any of you LS guys running 11:1 compression.....any problems w/ increasing the CR that much?
Old Nov 20, 2002 | 04:07 PM
jabroni95gsr's Avatar
Default Re: Piston install: process?? install fees?? (BlueTeg)
i was quoted $500 for a piston install on my b18c, and it would take 1-2 days.
Old Nov 20, 2002 | 05:13 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Piston install: process?? install fees?? (jabroni95gsr)
I was quoted $375 for mine, but that was if you gave the block and everything to them already out of the car. The price included balancing everything.
The 11.1 CR shouldn't cause too much of a problem at all. Many of my friends are running 12.5:1 on 93-94 octane on the street regularly.
Old Nov 20, 2002 | 06:15 PM
9integra2's Avatar
New User
Default Re: Piston install: process?? install fees?? (shamoo)
I'm not an experienced engine builder, but I don't see a reason why you'd have to remove the engine for a piston swap. I would think it would only need to be removed for convenience or machine work on the block.
Old Nov 20, 2002 | 06:51 PM
shamoo's Avatar
Default Re: Piston install: process?? install fees?? (9integra2)
This is true....but I just asked around anyway. I did the work myself, just asked to see if it was worth saving my own time.
I had everything out because I was doing a complete rebuild at the time.
Old Nov 21, 2002 | 08:46 AM
BlueTeg's Avatar
Thanks for the feedback you two.
keep it coming.
scootertribe
Feb 17, 2006 05:07 PM
lakerschamp2000
Sep 19, 2004 07:23 PM
Chuji
Jul 8, 2003 07:04 PM
BlackB18CTeg
Mar 13, 2003 05:35 PM
speedymon
Dec 31, 2001 06:43 AM
