pic request itr header bracket
Old Mar 22, 2008 | 06:30 PM
jdmdohcek98's Avatar
Default pic request itr header bracket
does anyone have a pic of it installed? i have a gsr with the itr headers on i bought the bracket and it looks like the part with the washer welded on uses the same bolt as the midshaft if im looking at it right so if anybody has a pic that would help alot thanks also i know i dont "need it and they eventually break" but i chose to put it on so please no negative comments thanks
Old Mar 22, 2008 | 06:59 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: pic request itr header bracket (jdmdohcek98)
Some of the later (spec 98+ if I recall correctly) JDM ITR headers had a different rear header bracket than the USDM.
This thing:
http://www.passwordjdm.com/pro...D=357
Old Mar 22, 2008 | 08:03 PM
Default Re: pic request itr header bracket (Dogginator)
yes i have the 98 spec headers and also the bracket im looking for a pic of the bracket installed on the block
Old Mar 23, 2008 | 05:15 AM
Dogginator's Avatar
Daisy... Daisy...
You will need one bolt that is slightly longer due the spacer. It installs in the exact holes as the stock mount.
Old Mar 23, 2008 | 05:53 AM
turboteg90's Avatar
pm for noodz
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">You will need one bolt that is slightly longer due the spacer. It installs in the exact holes as the stock mount.</TD></TR></TABLE>
i see your up early on sunday
Old Mar 23, 2008 | 07:34 AM
i never had the stock bracket either so thats why i dont know how it looks! so just to confirm the hole with the welded spacer goes on top of the midshaft and the other hole on the block. does anybody know the size of the longer bolt? can i get it from honda?
Modified by jdmdohcek98 at 8:59 PM 3/23/2008
Old Mar 24, 2008 | 01:45 PM
bump
boostedgsr1234
Oct 8, 2007 06:43 PM
nevin
Jun 18, 2004 12:34 PM
temp
Jan 21, 2004 06:23 AM
capcon83
Jul 20, 2003 07:50 AM
Tommy_Gunns
Jun 6, 2002 04:23 PM
