PCV question lsvtec
Old Aug 24, 2006 | 04:08 PM
POE's Avatar
POE
Default PCV question lsvtec
vtec will not engage in my car in 4th and 5th gear. i get the code 41 vtec oil pressure. I was looking around and noticed, then some time ago, but have yet to do anything. I noticed that there was a hose coming from the top of of my PCV (the black box) on the back of my block, This box had a hose that was just unhooked... under the intake manifold..
And i noticed today when i was looking around somemore. that the vacume hose from the top of the intake manifold, that run between the 2-3 primary runners and goes to some sort of plug thing.. has a hose coming out the bottom of it, but it was disconnect too..
This car has ran fine for over a year like this.
Would this be the cause of no vtec in 4th and 5th gear?!
Old Aug 24, 2006 | 05:02 PM
POE's Avatar
POE
Default Re: PCV question lsvtec (POE)
ttt
Old Aug 24, 2006 | 06:46 PM
POE's Avatar
POE
asdf
Old Aug 24, 2006 | 06:55 PM
saikouEF8's Avatar
.... ........ did vtec engage after you fixed those two things? i however doubt that thats the problem.
Old Aug 24, 2006 | 07:00 PM
saikouEF8's Avatar
Default Re: PCV question lsvtec (saikouEF8)
....https://honda-tech.com/zerothread/1718121 this is your last post about this issue. did u try anything that these people sugessted?
Old Aug 24, 2006 | 07:01 PM
Dartanian's Avatar
By your description, it sounds completely unrelated to not having vtec in 4th and 5th.
Old Aug 25, 2006 | 12:03 PM
POE's Avatar
POE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saikouEF8 &raquo;</TD></TR><TR><TD CLASS="quote"> ....https://honda-tech.com/zerothread/1718121 this is your last post about this issue. did u try anything that these people sugessted? </TD></TR></TABLE>
if u read the entire post. i explain... thanks..
Rishiras
Apr 22, 2007 04:47 PM
POE
Aug 25, 2006 12:04 PM
phateless
Oct 16, 2004 06:37 PM
