pass window has trouble rolling down
Old Dec 16, 2002 | 06:39 PM
E-Rok's Avatar
EPIC TUNING
Default pass window has trouble rolling down
Ok my pass window rolls down fine about 1/3 of the way, then it stops, or goes REALLY slow another 1/3 down, then the last 1/3 it goes down fast liek usual. going up it has no problems. any idea what it can be? sometimes once it gets to that point it just WONT go down, then it will go after a while, doesnt seem electrical since it occurs in the same spot, and rolls up fine.
Old Dec 16, 2002 | 06:52 PM
P0sTaL's Avatar
Default Re: pass window has trouble rolling down (rewsnaeht)
hey i had the same problem, but i fixed it and this is what i did. Ok well i took out the door panel on the inside and rolled down the window. theres a little tab on the inside of the door panel u took off that should be tight. and when u but the door panel back make sure the window is down. I did this and after that never had the prblem. the tab is on the lip on the inside it looks like its holding the rubber but the tab has to be tight and it gets loose in some tegs ive done 3 tegs for my uncle at his shop not includidng mine. Well let me know how it truns out make sure that u install the door panel correctly theres a special way so all the slits are correct in place..
Old Dec 16, 2002 | 06:53 PM
JMX's Avatar
JMX
same here only on my drivers side, and when its cold out it dosent want to go down at all.
i think the track just needs to be greased
pdx_503
Oct 3, 2007 11:12 AM
Red_EM1
14
May 11, 2004 09:31 PM
GeorgeY
Mar 28, 2003 12:23 PM
RATEDR
May 23, 2002 06:39 AM
