Parts required for VALVE ADJUSTMENT??
Old Feb 18, 2008 | 09:17 PM
JDMEK9R's Avatar
Default Parts required for VALVE ADJUSTMENT??
Im getting my valves adjusted and was wonder if i had to replace the head gasket when i adjust my valves. I was told i should just purchase the oem acura head gasket set. I was also wondering whats the difference between the these two. part # 12030-P30-000 and part # 12030-PR3-000. http://www.sonsacuraparts.com/...dIrno=
Thanks,
-Mike
Old Feb 18, 2008 | 10:48 PM
alexisthemovie's Avatar
valve cover gasket, not head gasket.
Old Feb 18, 2008 | 11:50 PM
goota's Avatar
all you need is a valve cover gasket, some hondabond and spark plug seals. just in case you mess them up when you take off your valve cover.
as for adjusting the valve clearances, i just use the valve clearance shim things, a socket wrench and a screwdriver, but you gotta develop a technique so that way when you tighten it, it goes to the right clearance, anyways its cheaper than buying one of those valve adjustment tools. its faster for me, and my valves are always in spec
Old Feb 19, 2008 | 01:17 AM
JDMEK9R's Avatar
Default Re: (goota)
ahh ic, could you show me which part that would be on sonsacuraparts.com, also i was told by a shop that i would need the valve cover gasket set? could you also show me that on sonsacuraparts.com. i thought it was the head cover gasket set but ive been told otherwise.
Old Feb 19, 2008 | 02:19 AM
98BabiGs-T's Avatar
Default Re: (JDMEK9R)
Should be #6 on a B18A/B and #5 on the B18C
Link...
Edit: The gasket set your referring to is just all the gasket/washer/bolt combine.
Modified by 98BabiGs-T at 3:30 AM 2/19/2008
Old Feb 19, 2008 | 05:30 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Parts required for VALVE ADJUSTMENT?? (JDMEK9R)
This is a nice how-to:
http://www.c-speedracing.com/h...t.php
Old Feb 19, 2008 | 06:17 AM
StReCh4130's Avatar
Default Re: Parts required for VALVE ADJUSTMENT?? (Dogginator)
good stuff
Old Feb 19, 2008 | 02:42 PM
JDMEK9R's Avatar
Default Re: Parts required for VALVE ADJUSTMENT?? (StReCh4130)
thanks for all the help guys
LukieLuc
Feb 29, 2008 06:05 PM
Shaguar47
May 28, 2007 08:47 AM
RaceMyGhost
Jul 7, 2006 11:03 AM
zapps
10
Aug 31, 2004 07:21 AM
Frito1
Jan 10, 2002 08:14 PM
