p28 help
Old Nov 30, 2002 | 05:20 PM
vtec69's Avatar
Default p28 help
I was installing my chipped p28 ecu into my friends 2000 gs-r with a obd2-obd1 harness and when we start it up the car starts for a second then the rpms just drop and the car stalls.
Has this happened to anyone?
Could it be the harness or the ecu or is it just not meant for a gs-r?
Any help would be greatly apprecaited
TIA
-BRian
Old Dec 1, 2002 | 06:06 PM
vtec69's Avatar
Default Re: p28 help (vtec69)
anyone????
Old Dec 1, 2002 | 06:46 PM
TRuST's Avatar
Do you get any check lights ?
Old Dec 1, 2002 | 06:53 PM
90Zcrx's Avatar
The ECU can run the engine just fine if it's got a DOHC program on it. What program is in it? And are you certain the jumper is for the right year of GSR?
If you're running a stock p28 it'll run like crap, you need a DOHC program on it.
Old Dec 1, 2002 | 06:59 PM
vtec69's Avatar
Default Re: p28 help (90Zcrx)
Im not sure if the harness is for a 00 gs-r i got it for my 98 civic which im putting a ls/vtec in a few weeks. Its a mugen program just using that program to test out the ecu.
Old Dec 2, 2002 | 02:27 AM
90Zcrx's Avatar
you HAVE to have the right jumper, there's two different OBD-2 to OBD-1 Jumpers.
Old Dec 2, 2002 | 03:34 AM
kenji's Avatar
25 Year Member
Here is the correct answer:
https://honda-tech.com/zerothread?id=347434
-kenji
bOOsT-FeIn
May 1, 2011 08:35 PM
kevs-ej1
Aug 12, 2009 03:17 PM
vtec69
11
Dec 1, 2002 06:05 PM
