OVerheating problems Help
Old Dec 16, 2004 | 09:39 PM
bubblebackinSI's Avatar
Default OVerheating problems Help
Ok so I have aem ems and i was checking the coolant temp and it was reading 212 when i was still but when i drive it goes down to 185 190. The upper radiator hose does not have much pressure in it cause i can squeeze it but it is hot and also the fan isnt turning on. I already replaced the radiator and checked the fan fuse and its not that so do u think it is the thermostat. Or do u think i blew a headgasket? I hope not but when i did the radiator swap there wasnt any signs of a blown headgasket nothing in the overflow and the inside of the hoses were clean no gunk. HEllppppp me please anyone have this problem before cause i searched already and nothing of this kind came up.
Old Dec 16, 2004 | 09:51 PM
Default Re: OVerheating problems Help (bubblebackinSI)
anyone
Old Dec 16, 2004 | 10:59 PM
Slain's Avatar
are you blowing any smoke out the exhaust ? is there a milky liquid in your oil ? change the thermostat as its a fairly cheap item to replace.
Old Dec 17, 2004 | 07:17 AM
Default Re: (Slain)
well its cold so i am blowing smoke out of the exhaust but i checked my oil and it is clean as a whistle
Old Dec 17, 2004 | 08:22 AM
IVI's Avatar
IVI
Default Re: (bubblebackinSI)
if the top hose is not really hard that means your thermostat is not stuck, good.
if your fan is not coming on, that seems to be the problem.
i dont think its your headgasket
i dont think its your thermostat, check the cooling fan system.
relays, fuses, wires....
Old Dec 17, 2004 | 08:54 AM
trellix78's Avatar
New User
Default Re: (IVI)
Have you checked the fan switch and temperture sending unit underneath
the distributor?
The manual says how to check both of them to make sure they're operating
correctly.
Also, check that the thermostat is opening when it should. Sometimes an
old thermostat can take too long to open.
Old Dec 17, 2004 | 02:15 PM
Default Re: (trellix78)
ok well i did the thermostat today and checked the cooling fan fuse and its fine. The fan is now turning on and my temp looks good on the cluster letter im going to check the temp on the aem. What is the highest and lowest temp that the car should go to at idle?
woob87
Feb 26, 2018 10:30 PM
Chemi421
16
Feb 18, 2008 05:30 PM
tonezilla
Mar 22, 2004 07:35 PM
sol2nr
15
Feb 20, 2004 09:17 AM
fasterthenmost
Sep 11, 2002 02:37 PM
