overheating problem...HELP
Old Oct 7, 2007 | 10:11 AM
qwk db8's Avatar
Default overheating problem...HELP
i have a 98 gsr yesterday i blew the radiator ...replaced it and its still overheating...for some reson the cooling fan isnt working i checked the relay and its fine ac fan comes on when i turn it on but cooling fan dosnt anyone know what could be the problem...
Old Oct 7, 2007 | 11:00 AM
St Jimmy's Avatar
* B A N N E D *
Default Re: overheating problem...HELP (qwk db8)
Its probably not the fan check your thermostat, radiator cap, overflow tank, and water pump. Those can all cause your car to overheat. Also did you bleed the system correctly after install of new radiator? Air bubbles in the system can cause it to overheat too.
Old Oct 7, 2007 | 06:43 PM
qwk db8's Avatar
Default Re: overheating problem...HELP (St Jimmy)
yea we bleed the system out and the fan wont go on at all im gonna replace the switch the car stays cool for awile till its time for that fan to kick in ...
adamrich33
Apr 2, 2012 04:00 PM
EGed up from the seat up
18
Jun 1, 2011 02:16 AM
turbotime
Nov 14, 2005 12:45 PM
LagunaSecaEG
Feb 9, 2005 12:54 PM
