overheating
Old Feb 23, 2010 | 09:34 AM
88crxdxfastwhip's Avatar
Default overheating
95 integra ls with gsr swap i just noticed that my car starts to overheat at a low rpm or idle other than that it runs good new thermostat fan hookedd to switch no oil in water no water in oil headasket was replaced when i swaped the motor but was overheated shortly after due to a broken hose helppp white smoke high rpm
Old Feb 23, 2010 | 11:53 AM
DumaDA's Avatar
Default Re: overheating
Have you done any compression or leakdown tests?
Old Feb 23, 2010 | 03:19 PM
flash69's Avatar
faulty radiator?
Old Feb 23, 2010 | 03:20 PM
DumaDA's Avatar
sounds like it, if the thermostat is good and the coolant level is correct then radiator would be my guess
Brent1204
Aug 18, 2015 02:09 PM
@imraging
Aug 10, 2014 05:13 PM
dsands7
Aug 21, 2012 10:29 PM
E_F_9
10
Jun 18, 2012 08:14 PM
ALF
Jul 12, 2005 03:14 AM
