Overheating!
Old May 5, 2008 | 06:30 AM
sprco's Avatar
Default Overheating!
So I tried searching but there weren't any topics that fit my situation (at least I don't think so)
I had a leak from one of the coolant hoses, one of the smaller ones that runs from the firewall and towards the head, anyway so I replaced that hose and now I have like a pressure build up in the top coolant hose and from the radiator, I cant drive for like 5 miles without overheating. It doesn't smoke or anything until I let the pressure out from the rad.
Do I have a bad radiator cap? Any help with this would be awesome, I'm trying to avoid going to the shop
Old May 5, 2008 | 07:25 AM
tegb20's Avatar
Default Re: Overheating! (sprco)
You should check your cap and your thermostat since when they mess up they dont open or close when needed if those aren't your problems your radiator may be clogged and if not that your heads are busted and water is getting in your engine........Start from the bottom though first and work up......
Old May 5, 2008 | 08:14 AM
sprco's Avatar
Default Re: Overheating! (tegb20)
thanks, ill try that
Old May 5, 2008 | 08:23 AM
legomytego's Avatar
i agree start small to big and they are the cheap so i would get oem my buddy tegdude227 on here got a hole new coolent system i mean rad fans hoses everything only to find out that his cheap *** waterpump he got from autozone was broken in 2 places so go to acura and do your self a favor
Old May 5, 2008 | 12:00 PM
sprco's Avatar
Default Re: (legomytego)
So what are you saying just go to the dealership?
Old May 5, 2008 | 01:25 PM
sprco's Avatar
Default Re: (sprco)
So now the car drives fine and the temp stays at a stable range but when I stop at like a traffic light for a extended time, the temp rises until I start moving again.
Is there any other suggestions or is it the same?
Old May 5, 2008 | 02:14 PM
95_B18b1_Teg's Avatar
Default Re: (sprco)
turn your car on and pop the hood
wait five minutes while it warms up and look around and see if you you need to top off any fluids while your waiting for the fans to turn on
if they dont it could be your fan switch by the thermostat housing
its like 22-32 bux depending where you go
Old May 5, 2008 | 02:38 PM
yangtech's Avatar
did you bleed the coolant system..?
Old May 5, 2008 | 04:52 PM
sprco's Avatar
Default Re: (95_B18b1_Teg)
Is there a diagram for a b18b1 engine because I'm not sure where the thermostat is
Old May 6, 2008 | 07:30 AM
tegb20's Avatar
Default Re: (sprco)
The thermostat in most cars is found at the end of the top main radiator hose......Like the dude above me said too, turn your car on check if you have any leaks as your water pump may be leaking and so that causes it to overheat as well.....As you wait check if your fans turn on if not then theres your problem as when your moving the air thats being pushed in to the engine bay cools the water and engine......So if they arent turning on you'll need to buy the fan switch, if your on a tight budget go to the junkyard and get one from there...If your even tighter then just put em direct so that they are always on I wouldnt really recommend it since your fans will end up burning out....
Soooogie
Sep 29, 2013 04:54 AM
alvinahmed
Sep 16, 2012 09:32 AM
stevej1
Jun 29, 2010 09:17 PM
Ser1N
Oct 30, 2008 11:54 AM
mickey513
Dec 20, 2004 02:22 AM
