over heating
Old Feb 25, 2006 | 03:59 PM
NYCxTEG's Avatar
Default over heating
my car was over heating, but cooled after 3 min or less... so i thought it was the termostat not opening up.. so then i change the stat.. now it doesnt cool back down to normal temp.. pls help
Old Feb 26, 2006 | 09:10 AM
jdmda9's Avatar
Default Re: over heating (NYCxTEG)
i had the same problem where my car was over heating like a mother. i've learned that if you use a aftermarket thermostat, they dont always work well, sounds stupid but trust me. get your self an oem if you dont already have it. it also can be(like in my case) that you fan has failed, so you might have to wire it directly, where you control it with a switch., you also might want to try to bleed the system when your replacing you thermostat,if all this fails then good luck.
Old Feb 26, 2006 | 09:57 AM
.xcalibur.'s Avatar
make sure your fan runs fine and flush out the radiator in case its a bit clogged. Aftermarket thermostats are fine.
Old Feb 26, 2006 | 11:58 AM
NYCxTEG's Avatar
Default Re: (.xcalibur.)
anymore suggestion.. pls help... thnx in advance
Old Feb 26, 2006 | 12:05 PM
R-81DC2's Avatar
Default Re: (NYCxTEG)
nice ***
Old Feb 26, 2006 | 12:10 PM
.one lane's Avatar
.likes trains
You probably just have air in the system. Just flush out your cooling system.
Old Feb 26, 2006 | 12:23 PM
salman's Avatar
If you havent removed the air from the cooling system after installing the Stat .,then its the air .
jeremyrocksursox
Aug 27, 2009 07:29 PM
TEGSTEG
11
Oct 16, 2007 07:56 AM
PreIudeSI
Aug 24, 2004 09:55 PM
Dean80Z28
Apr 28, 2004 04:59 PM
shadowdawn
Oct 7, 2003 01:04 PM
