open header?
Old Oct 20, 2007 | 07:16 AM
1a's Avatar
1a
Default HELP!!!!! OPEN HEADER PROBLEM?
im going to the track and want to see how it will run with open header.... some people say you need the back pressure but ive seen a few hondas run awesome without it. but myt main question is anyone who has done or has an open header.... do you know how much hp you gain? and if your running rich what will happen then, and do you notice a pull in power?
Modified by mck52689 at 9:53 AM 10/20/2007
Old Oct 20, 2007 | 09:32 AM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: HELP!!!!! OPEN HEADER PROBLEM? (mck52689)
if (car == stock) {fail;}
Old Oct 20, 2007 | 10:18 AM
suspendedHatch's Avatar
It's going to run horrible.
You never need/want backpressure. You want scavenging. One cylinder fires at a time. After it fires, the exhaust valve opens up and the exhaust shoots out (positive pressure followed by negative pressure). The intake valve is slightly open at the same time (overlap). Basically you want the vacuum created by one cylinder's exhaust pulse to pull incoming air into the next cylinder.
Another part of the equation is that the shorter the exhaust length, the higher the peak hp moves in the power band. Open header theoretically moves the peak hp in the 20,000+ RPM range.
People take these ideas from old domestic high displacement cars. Domestic cars are so poorly engineered that you can make a lot of power just by getting out of the way of the airflow. Hondas/Acuras are precision engineered to make the most power out of the least displacement. Changing things w/out knowing what you're doing screws things up and you more often lose power.
You run rich to keep your engine safe from detonation under high load and RPM. But you're compromising power for safety. In many cases, running somewhat lean gives you the best power, but this is just a generalization to demonstrate my point.
Running open header could also burn a valve. Have fun.
Old Oct 20, 2007 | 10:21 AM
1a's Avatar
1a
Default Re: HELP!!!!! OPEN HEADER PROBLEM? (suspendedHatch)
alright i think i made my mind up after that haha... idk im broke right now and im just trying to see my options... also the idiot before me had the clutch pedal raised way up there and it sucks driving it... any one know how to change the height and engagement?
Old Oct 20, 2007 | 10:24 AM
super_mut's Avatar
If your car is cable a cable transmission then just adjust the clutch cable.
Old Oct 20, 2007 | 10:25 AM
1a's Avatar
1a
Default Re: (super_mut)
it is but i dont have a book or **** for it and idk how to do it
gearheadcurt
Engine Management and Tuning
Sep 1, 2009 03:43 AM
Kurly
Apr 20, 2008 10:29 AM
91preyludesi
Oct 29, 2005 12:20 PM
ITRacer121
70
Mar 29, 2005 02:34 PM
baggelis
Feb 25, 2005 10:34 AM
