Oiling K&N Filter
Old Aug 27, 2001 | 11:56 AM
miketegra's Avatar
Default Oiling K&N Filter
Is it possible to over-oil a K&N Filter?
I got a little jiggy with the oil last night and it's not dripping, but I definintely made more than a pass or two.
It leaves oil on my hand when I touch the filter.
Should I clean and re-oil with less oil? or not worry about it?
Old Aug 27, 2001 | 12:17 PM
IN VTEC's Avatar
Default Re: Oiling K&N Filter (miketegra)
Don't worry, be happy.
Old Aug 27, 2001 | 01:55 PM
miketegra's Avatar
btt
Old Aug 27, 2001 | 02:04 PM
samagon's Avatar
I know that it says to let it dry for a while after you wash it, but how long do you guys really let it dry for? I don't have a day or two to let it dry, as I am always on the go.
any recomendations?
keys's Avatar
yes it is possible to over oil the filter.... basically if the filter is dripping oil then you oiled it too much, but as long as no oil is dripping and it is soaked in oil then it should be fine
Old Aug 27, 2001 | 02:05 PM
keys's Avatar
Default Re: Oiling K&N Filter (samagon)
just leave it outside or in the sun for 30 minutes...... over here's it's like 90 degrees in the sun so that should be enough
Old Aug 27, 2001 | 02:51 PM
JM Performance's Avatar
Default Re: Oiling K&N Filter (keys)
how often do you guys clean and oil your filters? mines going on 8,000, plus I bought it used and the guy said he put nearly 3,000 on it.....so it has atleast 11,000 on it
I guess I should do it soon, huh?
Old Aug 27, 2001 | 10:46 PM
keys's Avatar
Default Re: Oiling K&N Filter (00SilverLS)
i'd say if it were a drop in filter then every 12,000 miles would be good..... if you have an external filter like the AEM CAI then cleaning should be done around every 6,000 miles
Old Aug 27, 2001 | 11:16 PM
Pat's Avatar
Pat
if you see more white than red then that would be time to re-oil!
Old Aug 28, 2001 | 08:43 AM
miketegra's Avatar
Default Re: Oiling K&N Filter (Pat)
Thanks for the advice guys. I double checked the filter last night. No runs drips or errors. Nothing oozing, or making it's way up the intake pipe, nothing icky, yucky, OR nasty.
The car seems to be running better, but it looks like my fuel mileage is WAY down.....perhaps I should re-set the ECU ? Maybe coincidence?
HMMMMMMMMMMMMMMMMMMM>>>>>>>&g t;>>>>>.................??????????
Old Aug 28, 2001 | 09:05 AM
samagon's Avatar
what if I see all black? is that bad
Old Aug 28, 2001 | 09:13 AM
rockwilda's Avatar
will autozone/pepboys type stores carry the reoiling kits? i need to reoil my CAI filter
Old Aug 28, 2001 | 09:41 AM
BoM's Avatar
BoM
Default Re: Oiling K&N Filter (da_rockwilda)
i got mines at pepboys 8 bucks...
brucepick
May 2, 2010 02:54 PM
Pussy_magnet_00
Dec 5, 2007 07:43 PM
TeGGY_LS
Aug 6, 2004 01:16 PM
GGSSRR
Sep 6, 2001 09:10 PM
