oil pump question?
Old Nov 13, 2006 | 01:51 PM
AMLS4dr200whp's Avatar
Default oil pump question?
hey guys how are you good I want to know how you can tell which oil and water pump belong to which b-series I been searching but cant find it let me kno thanks
Old Nov 13, 2006 | 02:00 PM
doood's Avatar
been there done that
Default Re: oil pump question? (AMLS4dr200whp)
im not sure on the oil pumps, but for the water pumps 19 tooth are non vtec and 22 tooth are vtec.
Old Nov 13, 2006 | 06:56 PM
Sam92Teg's Avatar
Default Re: oil pump question? (that one doood)
I don't know all the ins and outs for all years. As for oil pumps, all 96 and newer are the same vtec or LS. As for earlier years, some had CPS, crank positioning sensor, some not. Earlier model LS and VTEC oil pumps were different.
Also there was a post where someone took the different oil pumps apart and claimed the only difference was a washer at the oil control spring. That must be one expensive washer because the price difference was like $50 between pumps.
I have a 92 RS, and I will be going with a newer 96 and up oil pump. The lower cover might need trimming because of the CPS provision. But it is a better pump and much cheaper than the OEM 92 model pump.
Also remember, if you use a vtec water pump, use a vtec timing belt, and likewise with the LS water pump, use an LS timing belt. I hope all of this is correct, if not, someone bitch slap me and correct it.
Old Nov 14, 2006 | 10:07 AM
Default Re: oil pump question? (Sam92Teg)
cool guys thanks for the help
JMd16z6T
Jun 12, 2015 04:36 AM
Layzboy713
Dec 16, 2014 06:08 PM
hydroflip
Aug 6, 2007 02:07 PM
Jeanious
Aug 3, 2007 09:09 AM
civicswap
May 21, 2005 06:24 PM
