oil light problem
Old Aug 17, 2006 | 02:36 PM
DC_RaceR's Avatar
Default oil light problem
My oil was on, but was very dim. (low).
Engine B18a
I decide to change out the Oil pump to type R one, and the pressure sensor..
I was running fine after the change. for 10 miles. (1 day)
Next day the oil light flickers...
Any other problem that could cause this light to flicker or be on.?
going to go buy a oil gauge this weekend..
Old Aug 17, 2006 | 05:51 PM
DC_RaceR's Avatar
Default Re: oil light problem (DC_RaceR)
up :
Old Aug 17, 2006 | 06:17 PM
BrianZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC_RaceR &raquo;</TD></TR><TR><TD CLASS="quote">My oil was on, but was very dim. (low).
Engine B18a
When does the light come on? is the car hot or cold? are you driving or at idle? what oil are you using? what oil filter are you using?
have you checked the wiring? if the oil presure sensor wire grounds out it can make the light come on. Get the pressure gauge installed, that will tell you a LOT more of whats going on
Old Aug 17, 2006 | 07:37 PM
DC_RaceR's Avatar
Default Re: oil light problem (BrianZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrianZ &raquo;</TD></TR><TR><TD CLASS="quote">
have you checked the wiring? if the oil presure sensor wire grounds out it can make the light come on. Get the pressure gauge installed, that will tell you a LOT more of whats going on</TD></TR></TABLE>
Lights come on 5 sec after car starts. Take's about another 10 sec to start flashing.
using 10w30 mobile. Fram filter. Wiring is okay.
Old Aug 17, 2006 | 09:34 PM
BrianZ's Avatar
try and disconnect the wire from the oil pressure switch and start your car.. see if the light come back on.
Old Aug 22, 2006 | 11:23 AM
DC_RaceR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrianZ &raquo;</TD></TR><TR><TD CLASS="quote">try and disconnect the wire from the oil pressure switch and start your car.. see if the light come back on. </TD></TR></TABLE>
Gauge installed.
Readings:
idle = 18-20 psi
2500= 50 psi
3500 = 50 psi
2500 = 50 psi while driving
4000 = 60 psi while driving
Is this normal?
The light is still on....
Disconnect the sensor and light is on.
Try to ground it.. nothing... light is on.
Old Aug 23, 2006 | 11:19 AM
DC_RaceR's Avatar
One more thing.
When the engine is cold....
1400 rpm...
it's 75 psi...
Seem like it's max out on 75 psi
Old Aug 23, 2006 | 01:01 PM
rdssk8rcs1's Avatar
yeah thats all normal, thats what mine used to do exactly....untill recently
Old Aug 23, 2006 | 02:43 PM
DC_RaceR's Avatar
Default Re: oil light problem (rdssk8rcs1)
but damm my light is still on....
I change out 3 oil pressure sensor so far and same thing.
I should brought the oil gauge first before throwing a new oil pump in....
Jaammeess21
Apr 11, 2017 10:12 AM
clh308
Dec 17, 2008 05:56 PM
Foxcow
10
Dec 16, 2004 08:56 PM
hondaracing1
Mar 27, 2004 05:38 PM
hondaracing1
Mar 27, 2004 01:46 PM
