oil light keeps flashing!!!
Old Aug 30, 2008 | 11:36 AM
itzyaboyzeem03's Avatar
Default oil light keeps flashing!!!
just as of yesterday my oil light has been flashing....my car runs fine...and it doesnt need anymore oil, but the light keeps flashing every now and then....whats going on???
Old Aug 30, 2008 | 12:23 PM
chevellion's Avatar
Default Re: oil light keeps flashing!!! (itzyaboyzeem03)
Maybe you should check it agian to make sure it doesn't need oil.
Default Re: oil light keeps flashing!!! (chevellion)
ok i'll go look at it right now
Old Aug 30, 2008 | 12:37 PM
so i added a lil bit of oil and now its a bit over the top line....so im sure it has enough oil now.....
Old Aug 30, 2008 | 12:39 PM
chevellion's Avatar
The oil light probably comes on when you take some fast corners then the oil settles back down causing the light to turn off.
Old Aug 30, 2008 | 12:42 PM
91redteg's Avatar
That light doesn't mean low on oil. It means low oil pressure. That's usually caused by being low on oil but it can be caused by a few other things. A failing oil pump maybe or gunk built up in oil passages
Old Aug 30, 2008 | 01:15 PM
Default Re: oil light keeps flashing!!! (91redteg)
so i guess its time for a new oil pump...i dont think they changed the oil pump when they did my swap
Old Aug 30, 2008 | 01:57 PM
BoSox46GSr's Avatar
well before you go swapping out oil pumps, there are other things that will cause low oil pressure. Check the sending unit. Any CEL?
Old Aug 30, 2008 | 02:39 PM
SkyliteCustomz's Avatar
check the wire that goes to the oil pressure sensor. Mine got loose and was causing the light to flash randomly.
Old Aug 30, 2008 | 07:03 PM
Default Re: (SkyliteCustomz)
where is the oil pressure sensor at on a b18b1??
Old Aug 30, 2008 | 10:59 PM
Default Re: (itzyaboyzeem03)
i took a look at the engine...and it seems as if it has a leak around the valve cover...im thinkin its leakin from the gasket...would that cause the oil light to flicker on and off?
Old Jul 1, 2016 | 12:36 PM
Sanfordansons's Avatar
Old Jul 1, 2016 | 03:03 PM
REPTAR's Avatar
VC gasket wont make the oil light come on. every car but one, that I have owned has had a leaky vc gasket at some point. and that one was a rotary so no valve cover! man I miss that car......
Old Jul 1, 2016 | 04:40 PM
fcm's Avatar
fcm
Old Fart
Next to the oil filter. 94
IBriaIN
Feb 27, 2011 08:28 PM
mtownek9
Apr 1, 2008 01:54 PM
coronadrinker
Nov 18, 2006 04:05 PM
JStar
Apr 6, 2006 02:29 PM
dbailey
14
Dec 13, 2004 02:23 PM
