Oil Issues???
Old May 19, 2006 | 11:23 AM
DpQInteg's Avatar
Default Oil Issues???
hey there was wondreing i think my car is burnign alot of oil.. its not dripping oil or anyhting.. but yea i had an oil change like 3 weeks ago and its gone down alittle... its a gsr 1998. and when i did my spark plugs today i found there were some oil on the spark plugs... answres pleae?
Old May 19, 2006 | 02:12 PM
jay_96teg's Avatar
Default Re: Oil Issues??? (DpQInteg)
Oil on your spark plugs means that your tube seals are leaking. Usually there is an upper and a lower set of tube seals. The upper seals are in the valve cover, the lower ones are under the rocker assembly.
Your oil level is either leaking or being consumed.
Check again for leaks and check for smoke comming out of your exhaust.
Good Luck
JAY
Old May 19, 2006 | 02:19 PM
s2kdre's Avatar
Default Re: Oil Issues??? (jay_96teg)
how much oil are u putting in? vtec motors take about 4.2 quarts, but i only put 4 in every time i change it.
Old May 19, 2006 | 02:22 PM
__oversea's Avatar
Default Re: Oil Issues??? (jdmhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda &raquo;</TD></TR><TR><TD CLASS="quote">how much oil are u putting in? vtec motors take about 4.2 quarts, but i only put 4 in every time i change it.</TD></TR></TABLE>
and your vtack works? even you put 4q, after crank engine, it will be like 3.8q due to oil goes into the oil filter.
gooberwolf
Sep 21, 2003 05:17 PM
GripFactoR
May 18, 2003 02:54 PM
B18C1 '96 Coupe
14
Apr 24, 2003 10:38 AM
redteg1
Aug 27, 2002 10:39 AM
Digital-R
Aug 2, 2001 12:59 PM
