Odd Electrical Issue's, blinkers/headlights etc'
My buddys integra is having some rather odd electrical issues', any pointers for starting points would be great'.
95 integra'
blinkers dont work
when headlights are turned on left blinker blinks and e-brake lights up on the cluster'
rather odd issues, i gonna take a look at it tomarrow or sometime this weekend, probably start by tracing back the blinker wiring and checking for voltage', any info would be appreciated
thanks fellas
95 integra'
blinkers dont work
thanks fellas
i would check the ELD it's under the fusebox haynes manual covers it. eld=electrical load or overload detector or something. i don't have it in front of me but i think that's one of the symptoms they even describe in the section on testing it. easy enough to test with a multimeter and then rule out.
alright, headlights work, corners work, blinkers light up', how-ever when headlights are on the blinkers fail to work properly
when the headlights are turned on the left side blinker stays solid, when the hazards are turned on with everything else off they blink
suggestions?
suggestions?
fasthonda94
Jan 7, 2013 05:51 PM
Dr. Willy
Aug 23, 2008 01:40 PM
ieatrice
Nov 1, 2003 05:28 PM
