OBD2A engine harness in OBD2B
What needs to be changed on an OBD2A (96-99) engine harness to get it to work on an OBD2B (00-01) main harness? Engine and main harness are both integra, Thanks.
I think the connecting plug at the shock tower is different. I may be wrong, but I know this was the case on my em1. Had to buy obd2b engine and interior harnesses to keep it factory clean. Or you can cut and solder or repin a plug.
Nothing, its not like the civics, The engine harness remained the same from '96 - '01 The interior harness did change, shock tower plugs remained the same. (note integra also did not switch to the smaller style distributor plug like the D-series civics)
The missing wire is for the tach signal. Depin A19 at the ECU and splice a wire onto it and connect it to the blue wire comming from the distributor that doesn't go anywhere on the engine harness side of the plug.
