OBD0 LS thowing code 43
Old Jul 28, 2009 | 04:07 PM
thirteen_20's Avatar
Icon2 OBD0 LS thowing code 43
what would be associated with the fuel system problem being diagnosed by the ECU? i just don't know where to start as far as what to fix? the car runs fine, motor needs a rebuild( rings, headgasket). sems to be running a tad rich. this code is only thrown after the motor is up to operating temperature. any help will be greatly appreciated. thanks in advance.
Old Dec 13, 2010 | 03:47 PM
zoidburg's Avatar
Default Re: OBD0 LS thowing code 43
bump same thing code 43 dont have money to throw at replacing parts but i do have a multi meter and lots of times, if i could just get a checklist of things to look for as far as what could throw a 43 on a 93 ls
Old Dec 13, 2010 | 04:02 PM
thissucksturtle's Avatar
could be anything fuel touches like gas cap , fuel filter , injectors, fpr and so on, some have had success changing the o2 sensor but that dosent work for every one
Old Dec 13, 2010 | 04:11 PM
fcm's Avatar
fcm
Old Fart
Start by checking the simple stuff first..
Vacuum leaks will throw a code 43, check all the vacuum lines.
Make sure the gas cap is in good working order and on tight.
I would also put a fuel pressure gauge on the system, see what the pressure is and check the FPR, the O2 sensor can also throw a code 43. 94
Old Dec 13, 2010 | 07:45 PM
Cripton805's Avatar
I had the same Code on my old LS. Most likely the o2 sensor. It's really REALLY easy to change out. Don't even bother paying to have it replaced. It's like 20 bucks at autozone if you use your old wire. It's only 1 wire and I think it was a crimp on
kenlrw39
Oct 26, 2008 07:53 PM
existanzcivicb20
Feb 8, 2008 04:27 PM
lamsv
Nov 23, 2005 10:13 AM
PhilStubbs
Jan 22, 2005 11:20 AM
oO
Apr 10, 2003 07:03 AM
