O2 Sensor/Knock Sensor problem
Old Jun 6, 2006 | 11:17 AM
AllMotorDB2's Avatar
Default O2 Sensor/Knock Sensor problem
Well last night I was leaving WAL-Mart and the car got really hesitant and would `not accelerate, After It finally stalled When I would try to start it the exhaust would just POP.So I toed it to my shop to realise the Bolt for the Ignition Rotor had fallen out causing the rotor to move around.
I replased the the rotor cap and screw.
The car would drive fine for about 20min and then Hestitate REALLY bad and the the power would kick back in causing the car to jerk excesivel.
I inspected the cap rotor and then changed the fule filter.Eerything seemed fine,drove good for 30min and than started hesitating again.Finally I got a code (43 Fuel System Supply) and code 23(Knock Sensor)
From what I described any clue on what would Trigger these Codes
Sorry for such a long post
any help would be great
Old Jun 6, 2006 | 01:35 PM
trick_db's Avatar
Default Re: O2 Sensor/Knock Sensor problem (DAintegraGSRdb2)
fuel pump?
Old Jun 6, 2006 | 03:36 PM
Default Re: O2 Sensor/Knock Sensor problem (trick_db)
Yea that sounds like a good posibility, Im gonna do a fuel prees. test tommorow
rasta420
Jun 8, 2007 01:59 PM
pinoy369
13
Apr 4, 2007 07:05 AM
alberto.garrido
Jul 27, 2004 09:33 AM
jakester
Jun 1, 2004 10:50 AM
elips0id
Jun 25, 2003 03:08 PM
