O2 sensor?
Old Jul 1, 2006 | 01:14 AM
JFG Kevin's Avatar
Default O2 sensor?
Hey, guys i'm having a bit of trouble trying to find out what's going on with my car. It's having trouble idling, i was wondering does a O2 sensor effect a car's idle by any chance? The reason why i ask this is cause i pull a code 43 every once in a while.
Old Jul 1, 2006 | 08:16 AM
DC2 Mang's Avatar
Default Re: O2 sensor? (aznstyler119)
I would change it to see what it does
also check timing and the IACV on the back of the intake manifold and FITV if you have one on your throttle body
Old Jul 1, 2006 | 10:17 AM
JFG Kevin's Avatar
Default Re: O2 sensor? (DC2 Mang)
Yah i cleaned out the IACV already..What is the FITV? I have a 2000 gsr motor.
Old Jul 1, 2006 | 12:22 PM
jared99's Avatar
Could there be a vacuum leak? Also maybe unplug the o2 sensor and see how it idles. The FITV is the fast idle thermal valve. Since your car is an '00 model I don't think you have one.
Old Jul 3, 2006 | 01:23 AM
JFG Kevin's Avatar
Default Re: O2 sensor? (jared99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jared99 &raquo;</TD></TR><TR><TD CLASS="quote">Could there be a vacuum leak? Also maybe unplug the o2 sensor and see how it idles. The FITV is the fast idle thermal valve. Since your car is an '00 model I don't think you have one. </TD></TR></TABLE>
Wouldn't unplugging the O2 sensor make the car rung worse...
Old Jul 3, 2006 | 01:09 PM
jared99's Avatar
Not if you "unplug" the wires at the connector. It just causes the car to go into open loop mode and disregard inputs from the sensor and use preset fuel mappings. If you were to unscrew the sensor from the exhaust and leave it hanging, then you might blow your motor or cause it to go into limp mode.
Old Jul 3, 2006 | 01:13 PM
LUXXXX's Avatar
fo sho
Jayboy
13
Jun 19, 2005 12:29 AM
ciRcuitJerk
10
May 13, 2003 05:18 PM
kHoA DoGG
26
Dec 28, 2002 09:14 AM
kHoA DoGG
Oct 31, 2002 11:44 AM
