Not getting spark...
Old Mar 29, 2011 | 04:18 PM
tranza's Avatar
Default Not getting spark...
Hi, got some problem with a 98 integra gs, the only way to get spark in the dizzy is by jumping the black/yellow cable(of the dizzy) with a positive direct from the batery. What could it be?. The engine is a b18b, stock Ecu, everything stock.
Old Mar 29, 2011 | 05:52 PM
jdm_bones's Avatar
Default Re: Not getting spark...
Sounds like a bad ICM
Old Mar 29, 2011 | 05:53 PM
lhd dc2's Avatar
Check the Ignitor or Ignition Coil. You can remove them and get them tested at AutoZone or your local auto parts store.
Old Mar 29, 2011 | 06:53 PM
tranza's Avatar
I tried with both thing, ICM and a new coil, still not getting spark, the only way is by jumpin the black/yellow cable with a positive 12v.
Its not the dizzy, the problem come from outside of it.
I am not getting 12v in the black/yellow rail. The two ground the front and thermot.. are attached.
Old Mar 30, 2011 | 06:27 AM
fcm's Avatar
fcm
Old Fart
Black/yellow is ign. power to coil assembly I would start at the ign. switch and work towards the distributor assembly testing for power on the ign. lead(s) when ign. switch is in run and start positions.
What is the MM&Y of the car? 94
Old Mar 30, 2011 | 02:20 PM
tranza's Avatar
The car is 1998, should i start checking from the ignitor switch?.
The car started great this morning but now the problem came back again. i noticed i couldnt shut down the car when i plugged the 12v into the black/yellow this morning, had to disconect it...then suddenly the car worked great without jumping the dizzy with the battery.
Could it be the fuse box? or the ign switch itself, bad ground?.
Old Mar 30, 2011 | 02:38 PM
Jimmy's Avatar
Global Moderator
Good info in here guys
Old Mar 30, 2011 | 04:33 PM
fcm's Avatar
fcm
Old Fart
Yes, test at the ign. switch harness, make sure the black/yellow, [ign. output] has 12V+ on it when ign. switch is in run and start positions... http://techauto.awardspace.com/ignitionswitch.html 94
jdancer987
Dec 31, 2011 12:47 PM
thangnhocngheo
Oct 10, 2011 08:27 PM
boostedG
Aug 17, 2011 05:52 AM
twotonecivic
Jul 30, 2008 06:21 PM
rizzoTK
Aug 29, 2005 02:35 PM
