Normal compression #'s for an LS
Old Jul 1, 2006 | 03:50 PM
96 GSR-T's Avatar
Default Normal compression #'s for an LS
What are average #'s for the LS? My boy got an 95 LS and out of the graciousness of my heart I did a comp. test for him today and was quite suprosed by the results...
Cyl1 195 Cyl2 200 Cyl3 150 Cyl4 210
Obviously he has a problem in 3 and #2 hole was filled with oil so when it drained in the cylinder it helped raise the #, but I figured they would be lower on the bone stock low 9:3ish comp LS.... this is an 170k motor BTW.
Old Jul 1, 2006 | 03:57 PM
trick_db's Avatar
Default Re: Normal compression #'s for an LS (96 GSR-T)
it seem fine except #3
Old Jul 1, 2006 | 04:07 PM
T3mp3sT's Avatar
Keep in mind it all depends on what guage you use as well.
A snapon one will read vary differently from a MAC or an Autozone brand one.
For instance..
My LS motor bone stock with a fresh rebuild on it did 180psi across the board on a Snapon, and did 205psi on a Autozone brand one (they read high because their diaphrams absolutely suck and tend to hold the psi spikes).
The thing you should be concerned with is the drop in #3. Generally speaking a 5% difference is ok... but thats outside of that range
Old Jul 3, 2006 | 10:36 AM
LsHoney84's Avatar
Default Re: (T3mp3sT)
Im curious about this as well. We have similar results. Ive got all my cylinder within the right range of each other (about 180) and my cylinder 3 is like 140.
Oh yea i have a 95 ls as well with about 140K miles
Old Jul 3, 2006 | 11:34 AM
PLAGUED_DB7's Avatar
Default Re: (LsHoney84)
# 3 is always a bitch.
My first engine after 70k I had 180 except 3. It was at 150
Boostage
211
Aug 12, 2009 11:11 PM
redDAinteg
May 25, 2005 04:31 PM
Aracheon
Feb 25, 2005 01:09 PM
spoonfed95
May 20, 2004 04:39 PM
vaporboy12
May 19, 2004 10:00 PM
