is this normal?
Old Jul 3, 2004 | 03:12 PM
pearlteg's Avatar
Default is this normal?
i just insatlled my skunk 2 IM and JDM ITR header with 2.5 cat now my car idels kinda high and then goes down to bewteen 1000 rpm to 0000rpm i was thinking i just need time for the ecu to reconize the new parts but i just wanted to know if it might be other issures. pic would help of the setup of the IM too
P.S. i have a 94 LS teg
Old Jul 3, 2004 | 03:38 PM
wreckedmyteg's Avatar
Default Re: is this normal? (pearlteg)
Sounds like your intake manifold gasket it leaking. Spray some carb cleaner around the head and IM, if it fixes it, you've got a leak.
Also check your throttle body gasket.
Old Jul 3, 2004 | 04:24 PM
17GSR17's Avatar
did u reset ecu
Old Jul 3, 2004 | 05:25 PM
Grease Monkey's Avatar
Default Re: is this normal? (17GSR17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 17GSR17 &raquo;</TD></TR><TR><TD CLASS="quote">did u reset ecu
Old Jul 3, 2004 | 05:56 PM
pearlteg's Avatar
Default Re: is this normal? (wreckedmyteg)
yeah i took out th e battery the whole timew we were doing the install. is tehre other way of reseting the ecu. i even chnaged all the gasket.
Old Jul 3, 2004 | 06:36 PM
rpms move up and down over and over?
Old Jul 4, 2004 | 11:46 AM
pearlteg's Avatar
Default Re: is this normal? (Grease Monkey)
i just took out the ecu fuse and now it ok but one thing i forgot to mention was that the throttle cable is not bolted where it should on the Skunk2 cus the bracket is touching the ATS air tep sensor, i was told i have to buy a ITR throttle cable bracket cus it extends long to the side...at this moment the rpm is at 1.5 when it used to be a 1 before the mod and ecu reset. so am thinking once i put the brackete and adjust the cable it should be fine. but input on my ideea is much appreciated.
tundra2000
Sep 25, 2010 10:24 AM
egbaby
Feb 24, 2008 12:30 AM
WTB AUTO EK
May 15, 2005 06:59 AM
i20ar
Jul 19, 2004 07:42 AM
Champ R
May 23, 2003 07:01 AM
