noisy window when rolled down
i can hear my glass clanking inside my door when the window is down and i hit a bump. i took the panel off and couldnt see anything loose or touching the glass.
any ideas?
any ideas?
track is bad along the side, mine is the same way, sounds like the glass is gona break it bangs so hard, on the inside of the glass towards the back of the door you will see a clip that glides the glass up and down the track, chances are one of those two pieces is worn out.
each individual piece should be able to be replaced, however i dont know how, i havent bothered to get into it on mine, check the diagrams on acura.com's parts store
there is a rubber piece that goes inside the track towards the bottom that either fell out or is worn out. in my case it fell out and was sitting in the crack of the bottom of the door and it looked like a piece of the door when i first saw it but once i took it out and cleaned it. i put it back into place in the track with some sealer to hold it in place and since then i havent had that issue. i only did my passenger side so if i get some free time this weekend i will do my drivers side and take pics so you see what i am talking about. Most people accidentally throw it away when they see it cuz they dont see where it goes.
http://acuraautomotiveparts.org/acur...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal #10/18 is the part the falls out, clean it and the "sash", [#5/16] apply a little contact cement and reinstall. 94
I've been having the same problem for two years now and still haven't fixed it, but since you bring it up.. i really need to get it fixed. I considered paying a shot to fix it.
Here is a link to a TSB.
http://www.acuraworld.com/tsb/1994/B94-016.pdf - window chatter
http://www.acuraworld.com/tsb/1994/B94-002.pdf - window speed too slow
