no start when cold
Old Oct 6, 2011 | 08:45 AM
Since 1983's Avatar
Default no start when cold
95 LS, no mods...
when the car is cold, like first start of the day, i turn the key and i get nothing, no starter, only the main relay click. If I hold it in thye start position it will usually start right up within a 30 count. when its been driven or is warm, no issue, its fine. All the grounds are fine, fuel pump kicks on, battery has correct voltage. Ignition switch? anyone have any suggestions?
Old Oct 6, 2011 | 05:45 PM
fcm's Avatar
fcm
Old Fart
Default Re: no start when cold
Originally Posted by Since 1983
95 LS, no mods...
Try a bypass jump to see if it cranks right away, [in the morning or when cold] you can also do a simple start circuit test with a 12V test light...https://honda-tech.com/forums/showth...&highlight=fcm 94
Old Oct 7, 2011 | 01:33 PM
agp35's Avatar
mine had the problem in the opposite way; when it was hot it wouldnt start but it did when it was cold. it turned out to be my relay (was unsoldering itself in the heat) and i fixed it. look more into the relay ? i know you said it clicks but mine did too... just an idea.
Bruce Banner
Dec 25, 2011 06:23 AM
coot_er
11
May 7, 2005 08:54 PM
Sexy_Chantal
Oct 28, 2004 04:18 PM
UNDER PRESSURE
Jun 21, 2004 08:47 AM
