No spark
91 teggy with no spark.. sometimes?
The battery keeps draining, i jump it and it starts, i then shut it off, when i go to turn it on again it just cranks and cranks but no start. i then check for spark and nothing. Dizzy? ECU? Thanks
are you sure check spark? because loose fitting boots or damaged cables can cause ignition misfire if it's fine, you probably have a bad fuel injector. but better change spark wires/plugs and battery. check main relay under dash and fuel pump prime. hope this help
