nitrous for the summer?
Old Jun 14, 2004 | 12:26 PM
gser67's Avatar
Default nitrous for the summer?
whats up everyone..i have been thinking about puttin my teg on the bottle just for the summer. ive desided i really would only want a wet system with a 50 shot so i stopped down at an "import shop" and this guy tells me that even with the wet systems you inject it into the intake tube! i was like WTF i thought that was a dry system and i told him i have an AEM rail that has an extra port for nitrous and he tells me he doesn know much about aem rails. i was like you are tryin to tell me about nitrous and you dont even know how a fuel rail works? anyway can anyone tell me if i can hook up a wet system into my aem rail(1/8 port) and are there any kits made specificly for this? thanks alot for the help in advance
Old Jun 14, 2004 | 01:42 PM
ninja8oi's Avatar
Default Re: nitrous for the summer? (gser67)
The extra port is to feed fuel to the fuel solenoid. It is still injected through the intake to the throttle body but with fuel and nitrous at the same time to prevent detonation. There is another setup called direct port and it is where you drill holes in your intake manifold and the fuel sprays directly from there. I had a nitrous kit before and personally did not like it. go turbo man. You'll be much happier. Refills cost crap loads and the power aren't consistent due to botte pressure.
Old Jun 14, 2004 | 05:41 PM
naturelovindc2's Avatar
Default Re: nitrous for the summer? (ninja8oi)
Wet system inject both fuel and nitrous at the same time. Dry systems only add nitrous and you'll have to make up for that by upping the fuel pressure or some other way.
Old Jun 14, 2004 | 05:43 PM
ECKOTYPER's Avatar
Default Re: nitrous for the summer? (naturelovindc2)
e's exactly right my ? to you is why nitrous only for the summer? thats the first time i've heard that i have a nx 75 shot in my gsr its a simple install man dont pay someone! its sooo simple as long as ur not incredibly stupid to follow the directions... get a purge and bottle heater if ur gonna do it pm if u need me to help u with the plugs u need timing retarding etc...
Old Jun 15, 2004 | 05:48 AM
gser67's Avatar
Default Re: nitrous for the summer? (ECKOTYPER)
oh yeah i was totally planning on doing the install myself..i was just wondering if there was any was i could run the shot right into my fuel rail(aem) or am i going to have to drill into my intake?
Old Jun 15, 2004 | 07:27 AM
ECKOTYPER's Avatar
into ur intake... its not as bad as it seems if ur gonna want to take it off later then just drill on the bottom part of the intake to where u cant see the hole its somewhat stealth to
Old Jun 15, 2004 | 10:43 AM
redrex's Avatar
If your goin to do direct port i think NX makes a kit for it
Old Jun 15, 2004 | 02:29 PM
GsrGilbert's Avatar
Default Re: nitrous for the summer? (redrex)
maybe u should take a look at Holley's big shot kit.
http://www.holley.com/HiOctn/P....html
Old Jun 17, 2004 | 10:16 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gser67 &raquo;</TD></TR><TR><TD CLASS="quote">i was just wondering if there was any was i could run the shot right into my fuel rail(aem) or am i going to have to drill into my intake? </TD></TR></TABLE>
You can't connect the nitrous to your fuel rail, it has to be injected somewhere into the intake tract. ie- intake tube, intake manifold runner, or even at the base of the injector with that new NOSsle system.
Having a good mixture or atomazation of fuel and nitrous is ideal, but they can't get mixed before they are injected into the motor. Make any sense?
HS2G
Oct 12, 2004 07:13 PM
IGGY
Dec 12, 2002 01:33 PM
crxracer91'
Jul 21, 2002 07:09 PM
