nitrous question
running the bottle is as safe as running any other Force induction, but most ppl dont have the right things while running nitrous which most the times end up blowing or damaging their motors! the things u should have while running nitrous is a aftermarket fuel pump/inline fuel pump, better ignition(msd),wires and colder plugs! There is also a lot of saftey options that can be purchase for the nitrous kits like a Microprocessor controlled Air/Fuel ratio switch tat will shut off the nitrous system if it goes lean or rich during a Nitrous run! This is just one of them!http://www.speedshop.org/store...ct=37
i also have friends who has been running nitrous for years and still have a strong motor! that is because there doin it right! I am goin nitrous myself so i had time too look into it! O yeah get a wet system and not a dry! Go wit the 50-75 shot!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GranSeries-R »</TD></TR><TR><TD CLASS="quote">O yeah get a wet system and not a dry! Go wit the 50-75 shot!</TD></TR></TABLE>
Why go with the wet shot instead of dry? Please explain to me. My Zex kit has lasted for 2 years and still going strong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GranSeries-R »</TD></TR><TR><TD CLASS="quote">running the bottle is as safe as running any other Force induction, but most ppl dont have the right things while running nitrous which most the times end up blowing or damaging their motors! the things u should have while running nitrous is a aftermarket fuel pump/inline fuel pump, better ignition(msd),wires and colder plugs! There is also a lot of saftey options that can be purchase for the nitrous kits like a Microprocessor controlled Air/Fuel ratio switch tat will shut off the nitrous system if it goes lean or rich during a Nitrous run! This is just one of them!http://www.speedshop.org/store...ct=37
i also have friends who has been running nitrous for years and still have a strong motor! that is because there doin it right! I am goin nitrous myself so i had time too look into it! O yeah get a wet system and not a dry! Go wit the 50-75 shot!</TD></TR></TABLE>
Damn... that had to be one of the best N00b post ever.
I'd also recommend a Remote bottlle opener and a MSD Iginition system where you can retard the timing from inside the car.
Thanx!
and for the clutch i recommend the ACT extreme kit! and as for the flywheel i hear good things bout the toda! I have a act 6 puck myself w/ a exedy pressure plate for road racing application and i aint too happy wit it and goin to go wit the extreme myself and i also have a CM flywheel and all i can say is it gets the job done!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtakSlayaw00t »</TD></TR><TR><TD CLASS="quote">Nitrous is ricer's only solution to running anything under 13s...Its pathetic how with only spending $6k, I can run hi 13s, give me $10k I will run 10s for cheaper than rice.</TD></TR></TABLE>
what the hell are you talking about? I'm not sure if you are ******* your own car or what.
If you are wanting a cheap and fast alternative to boost, Nitrous is the way to go. However a complete and advanced setup can end up costing a pretty penny.
my last set up retialed over $2k with all the nitrous only goodies i had. thats not counting the ignition stuff and fuel stuff to supplement it , just NOS stuff
LoL u spent 6k to run 13s wat kind of pos do u have a ******* saturn! give me $1500 and ill run 13s all motor from a stock GS-R!
Modified by GranSeries-R at 5:25 AM 5/30/2003
LoL u spent 6k to run 13s wat kind of pos do u have a ******* saturn! give me $1500 and ill run 12s all motor from a stock GS-R!</TD></TR></TABLE>
In what the 1/8th or 16th of mile?
I dunno what the hell you are putting on your car either, but 1500 bux to run 12s all motor is nearly impossible. Toda Spec Bs cost about 900-100 bux and those prolly wont even let you see 13s unless you have an exhaust.
Hell Toda VTEC killers cost about 1500 bux and you prolly make your car slower installing them unless you ran sport injection manifold + other goodies. So that's like 4-5K there. Hoping to see a High 12 or low 13.
1500 bux all motor 12s in the 1320. Bwhahaha if that was the case. I think all of us would be in the 12s. Full interior, AC, and Passenger.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P1mpSlap »</TD></TR><TR><TD CLASS="quote">
Let me correct myself! 13s
</TD></TR></TABLE>Let me correct myself! 13s
<-- used to run a 75 shot on GSR with i/h/e. everything else ... BONE STOCK
no need for aftermarket clucth!, igniton sysems!, or internal work.
the used NOS kit cost me 400... and it got me 13s.... (easy!)...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GranSeries-R »</TD></TR><TR><TD CLASS="quote">Let me correct myself! 13s</TD></TR></TABLE>
Everytime you post! I imagine you yelling!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TerribleOne »</TD></TR><TR><TD CLASS="quote">
Everytime you post! I imagine you yelling!</TD></TR></TABLE>
WAT U TALkING BOUT WILLIS!!!!
