Next mod suggestion
Old Jun 28, 2002 | 06:35 AM
Logan's Avatar
Default Next mod suggestion
Alright, ive got a 95 gsr with i/h/e.
I was just wondering what everyones opinions were on what my next mod should be. I am not going f/i and really just want to improve my times at the track.
Old Jun 28, 2002 | 06:56 AM
R-Rated's Avatar
Default Re: Next mod suggestion (Logan)
Suspension. Get some coilovers, TEINS.
95 GSR
[Modified by R-Rated, 7:56 AM 6/28/2002]
Old Jun 28, 2002 | 07:11 AM
ragejed's Avatar
Default Re: Next mod suggestion (R-Rated)
ya, i want tein SS. Someone told me there is another company ...forgot the name that makes them...they are from japan too
Old Jun 28, 2002 | 07:12 AM
98DC2's Avatar
intake manifold / tb....
Old Jun 28, 2002 | 10:18 AM
JDMCRVTEC's Avatar
Fuel pressure regulator, your opening the air flow, burning more fuel, so you can give the motor a little more fuel. and fuel pressure gauge.
Old Jun 28, 2002 | 10:19 AM
gotnothing's Avatar
Default Re: Next mod suggestion (98lagen)
Old Jun 28, 2002 | 10:22 AM
NVBAM's Avatar
Do you know any sites the have tein coilovers? Are they comparable to GC or Skunk2?
Old Jun 28, 2002 | 10:27 AM
gotnothing's Avatar
Default Re: Next mod suggestion (NVBAM)
Comparable as in price? No, you're looking at a bit more money. But you definitely get what you pay for. I got my Skunk2's for $180, Tein's will run you about $1000.
Old Jun 28, 2002 | 11:22 AM
NVBAM's Avatar
Default Re: Next mod suggestion (gotnothing)
Where did you get your skunk2's? I have been looking for awhile and they are all like $320ish...Thanks
Old Jun 28, 2002 | 11:26 AM
sackdz's Avatar
A higher final drive will do the most to lower the track times.
JDM 4.785
ATS 4.927
Cusco 5.0038
etc.
Per $ is the best mod , but it's good to install a new clutch and flywheel when putting it in.
Old Jun 28, 2002 | 11:36 AM
gotnothing's Avatar
Well, I got mine from a guy at this Honda dealership which used to have an aftermarket parts department. When the aftermarket department shut down, everything was sold off really cheap...
BTW, not even looking hard I found Skunk2's for $270 at inlinefour.com. I'm sure there are even cheaper prices out there.
Old Jun 28, 2002 | 11:41 AM
NVBAM's Avatar
Thanks a ton...I will probably order some within the week
Old Jun 28, 2002 | 12:16 PM
ragejed's Avatar
Tein SS from optauto.com for 950
Old Jun 28, 2002 | 03:51 PM
G2Integrity's Avatar
Short shifter or VAFC maybe.
Old Jun 28, 2002 | 06:26 PM
StyleTEG's Avatar
Default Re: Next mod suggestion (G2Integrity)
Highflow cat
Right now your H/E setup is not providing its optimal gains because you have a bottleneck with your stock cat.
Currently you are going from a 2.25" collector, to a 2" cat, back out to a 2.25" exhaust (or maybe worse if you got a 60mm exhaust or larger)
Old Jun 29, 2002 | 01:49 AM
Goy091's Avatar
cams
JUN 2's or 3's
Toda B's or C's
Skunk2 Stage 2's or 3's
valvetrain (springs retainers valves)
FPR
Hondata
Cam gears
LSD
dyno time
EDIT:high comp pistons
or go with
ITR/CTR cams
cam gears
FPR
VAFC
dyno time
throw on a some slicks mebe.
[Modified by Goy091, 10:50 AM 6/29/2002]
Old Jun 29, 2002 | 10:59 AM
broke1's Avatar
Old Jun 29, 2002 | 01:21 PM
B-series Assassin's Avatar
You should get a larger cat converter, but not a test pipe. If you dont really want to do a lot of tuning then a nice throttle body and intake manifold would do good. Or a JDM final drive. With the JDM final drive your gear ratios will stay the same, but you would accelerate faster.
If you dont mind tuning then go with Skunk2 Stage II cams and gears with the valvetrain upgrage. Then a VAFC for tuning lean/rich settings or manipulate VTEC crossover. If you have money go with a Hondata .
Old Jun 29, 2002 | 02:39 PM
Logan's Avatar
Default Re: Next mod suggestion (B-series Assassin)
what about a new clutch of lightened flywheel ?
Old Jun 29, 2002 | 02:47 PM
Yea that too . You need a new clutch if you're going to do more motor mods, so you can get all that power to the wheels.
Old Jun 29, 2002 | 06:01 PM
SoSoJeff's Avatar
VFAC
Old Jun 29, 2002 | 06:03 PM
IC x Prince's Avatar
New User
Default Re: Next mod suggestion (SoSoJeff)
ITR anti-sway bar....
Old Jul 4, 2002 | 01:16 AM
Cyclone21's Avatar
Da9Gro
Feb 18, 2008 06:35 PM
integra714
Oct 22, 2004 11:10 PM
TheGuy258
14
Sep 6, 2004 12:27 PM
SpoonPL
Jun 11, 2002 12:07 PM
